It is currently Tue Jul 08, 2025 6:55 am
Reply to topic  [ 2 posts ]
 longtail mount idea
Post longtail mount idea
i am building a longtail for my 27hp kawi and have an idea for the mount and looking for advise, so all are welcome to comment . i have a 1448 jon with 16" transom. my thought is the make thru hull mount with sealed bearings on the ends for vertical movement and for horizontal to use a heavy duty caster without the wheel arms mounted between two pieces of 3/16.only worry is the force that the forward thrust will put on the caster. do yall think it will work ? it will sure move easy im thinking. also should the motor be balanced center or a litte back to keep the prop in the water?
thanks for your thoughts and any ideas on building a mount
Wed Dec 19, 2012 9:59 pm
Post Re: longtail mount idea
Weve just used grade 8 bolts as pivot points on ours and its worked out good. Lock nuts on the ends and just make em tight enough to take out any play.
1436 Lowe
Thu Dec 20, 2012 12:35 am
Users browsing this forum: No registered users and 41 guests
