It is currently Sun Jul 06, 2025 9:37 am
[ 2 posts ] |
clintmiller92
 longtail mount idea
i am building a longtail for my 27hp kawi and have an idea for the mount and looking for advise, so all are welcome to comment . i have a 1448 jon with 16" transom. my thought is the make thru hull mount with sealed bearings on the ends for vertical movement and for horizontal to use a heavy duty caster without the wheel arms mounted between two pieces of 3/16.only worry is the force that the forward thrust will put on the caster. do yall think it will work ? it will sure move easy im thinking. also should the motor be balanced center or a litte back to keep the prop in the water? thanks for your thoughts and any ideas on building a mount
Wed Dec 19, 2012 9:59 pm |
SwampDonkey1
Joined: Tue Mar 08, 2011 10:09 pm Posts: 923 Location: North Central KS
 Re: longtail mount idea
Weve just used grade 8 bolts as pivot points on ours and its worked out good. Lock nuts on the ends and just make em tight enough to take out any play.
_________________ 1436 Lowe -Workin for the man, Huntin when I can...-
Thu Dec 20, 2012 12:35 am |
[ 2 posts ] |
Users browsing this forum: No registered users and 71 guests |
