It is currently Tue Jul 01, 2025 8:06 pm
Reply to topic  [ 8 posts ]
 LT on Gatortrax Rogue
Post LT on Gatortrax Rogue
Can you run a longtail on a Gator Trax Rogue with huntdeck? Or will the motor hit the false transom when you pick the prop up out of the water?
Wed Jan 23, 2013 12:48 pm
Post Re: LT on Gatortrax Rogue
the handle on the longtail has a curve that extends upward that allows for transom clearance. Since the motor is mounted further back I would think your chances of hitting the false transom are lower than with a traditional transom.
Wed Jan 23, 2013 12:52 pm
I believe the "tail" will hit the false transom. If mounted on the false transom it will be a bear to turn.
Thu Jan 24, 2013 9:03 pm
How do the Longtails fair with a huntdeck??? dont see to many of them after looking around the site...just curious
1652 Alumacraft Waterfowler / 35HP Backwater LT
Mon Feb 18, 2013 4:38 pm
Thu Feb 21, 2013 4:49 pm
Sweet thanks, so as in the thread above you just don't mount the motor on the huntdeck? Just the transom?
Thu Feb 21, 2013 9:25 pm
If you mounted it all the way back on the rear hunt deck transom it would be impossible to turn. You would have to be outside the boat trying to steer it.
Fri Feb 22, 2013 6:43 am
Touchè sir. Good call
Sun Feb 24, 2013 1:40 pm
Users browsing this forum: No registered users and 50 guests
