It is currently Sat Jul 12, 2025 11:18 am
Reply to topic  [ 35 posts ]
 23 or 25
Post 23 or 25
I have a 16x38 go devil boat and I'm thinking about getting a new motor for it. I currently have a 18 and it's ok I just want something to go a lil faster and and something to push that boat better than that 18. I like the Kohler motors but I also like the fact of having a pull start on the 23. That boat is heavy and I plan on removing the back pods and keep it open in the back so what y'all think would be better the 23 or 25?
23hp GDLT on 16x38 GD boat
When up to your nose in shit, don't open your mouth.
Tue Jun 18, 2013 7:18 am
Post Re: 23 or 25
Do you want a long tail of surface drive?
40HP Gatortail
Tue Jun 18, 2013 9:16 am
Post Re: 23 or 25
Go with the 27 prodrive
Jesse
27 PD FPR 16x36 skiff - aka - DITCH WITCH
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Tue Jun 18, 2013 9:22 am
Post Re: 23 or 25
25 Gtr. Will do anything you want or need it to do
17x48 extreme stage 2 GTR
Tue Jun 18, 2013 9:23 am
Post Re: 23 or 25
Looking for a long tail. I hunt a lot of swamps with cypress knees and logs and I just like my long tail in not saying that the surface drive can't make it where I hunt I just think it would be hard to do.
Tue Jun 18, 2013 9:46 am
Post Re: 23 or 25
Well in that case get you a 35 lt lol
Tue Jun 18, 2013 10:03 am
Post Re: 23 or 25
Get the 23. More mods for it
Tue Jun 18, 2013 11:12 am
Post Re: 23 or 25
Mud slinger what kind of mods I know there's not too much you can do to a long tail that's why I'm asking. I just want to go a lil faster with 3 people cause I'm pushing water right now if a 23 can give me that I'll get it cause I do like the fact they have a pull start.
Tue Jun 18, 2013 7:55 pm
Post Re: 23 or 25
why do folks suggest the 23 over the 25?
Uncle J 18x54
Gator Tail XD 37 EFI -Delta Performance Level 3
Tue Jun 18, 2013 11:04 pm
Post Re: 23 or 25
Twenty pounds lighter, pull start, ability to run with a dead battery, parts available everywhere .
Wed Jun 19, 2013 4:30 am
Post Re: 23 or 25
Carb exhuast cam the list goes on and on.
Wed Jun 19, 2013 6:09 am
Post Re: 23 or 25
so it is not a horsepower issue, it is a Vanguard engine versus the Kohler engine issue.
Uncle J 18x54
Wed Jun 19, 2013 6:54 am
Post Re: 23 or 25
Wed Jun 19, 2013 8:21 am
Post Re: 23 or 25
I learn something new everyday.
I have a 25 Kohler on a local built LT (called a Step Out Motor).
I did not realize that the Van had more options. I agreed that a pull start would be a nice option.
I was recently looking at some LTs made in Utah. I think they use a Subaru motor. How are they?
Uncle J 18x54
Wed Jun 19, 2013 11:40 am
Post Re: 23 or 25
Wed Jun 19, 2013 11:57 am
Post Re: 23 or 25
My old 25gdlt had a pulley on the back so you can pull start it. Worked fine...
Team Total ASalt
Mossy Oak Pro Staff
1854Gator Traxs w/HD pushed by a MB 5000.
Ams wrote:
If assholes could fly this place would be an airport
Wed Jun 19, 2013 2:47 pm
Post Re: 23 or 25
Tailfisher, although you could rig a pulley on the shaft it still needed a battery for the electronic ignition and the carb plunger solenoid to operate. I have owned both and like the 23 a little better.
Thu Jun 20, 2013 2:30 am
Post Re: 23 or 25
I think the extra push from the 25 is negligible on that hull and where you run. The big plus for the 23 Van you said yourself- pull start! I had the emergency hub on the 18 GD LT and it worked but not with a dead battery. The 23 is significantly lighter- another plus. Maybe the local dealer can let you test drive both motors? That should settle your decision. Of course, with the 23, you'll be spending several hundred dollars less. Apart from my first, an 18 Briggs GD LT, my other three have been Kohlers, two 25's, and my present 27- all have been solid performers; apart from the cold weather starting fickiness, they have been very reliable. I hear the same on the Vanguard 23. The one real lemon I have personally witnessed was the Honda 24- stay away from that one!
Thu Jun 20, 2013 6:19 am
Post Re: 23 or 25
Go with a backwater 23. More bang for the buck and great motor. I'm running a 16/48GD boat and am picking up my LT in 3 weeks when I make the drive up to MN. Good luck. http://www.backwaterinc.com/swomp-23.html
GD 1644-23 GDSD
Thu Jun 20, 2013 6:49 am
Post Re: 23 or 25
Thu Jun 20, 2013 7:31 am
Post Re: 23 or 25
Just givin you a hard time, but there really is a shit ton of options for the kohlers. Several different cranks so you have the option of building a stroker, and lots of different rods and pistons combos. Lots of other shit too that I haven't seen for the vans, but I haven't looked very hard either. Just sayin, they make an aftermarket part for pretty much every single stock part on the kohler, even have (or had) custom blocks on the small ones.
Thu Jun 20, 2013 9:03 pm
Post Re: 23 or 25
Longtail = 23 (these motors are like dick cancer...you can't kill it)
SD = 25
Thu Jun 20, 2013 9:04 pm
Post Re: 23 or 25
2015 1748 gator tail with drop deck. 2015 35 GTR :
Thu Jun 20, 2013 9:12 pm
Post Re: 23 or 25
Thu Jun 20, 2013 9:14 pm
Post Re: 23 or 25
Thu Jun 20, 2013 9:16 pm
Post Re: 23 or 25
They ain't that hard to find though and you implied that they weren't available. :lol: There is a shit ton of parts out there. If I had any interest in comparing those two engines, I would look it up. I owned a kohler so I looked for parts on them. I never owned a small van, so I've never tried to source parts for them, but I wouldn't tell someone that there weren't any out there. :lol:
Honestly, I wouldn't go down that path again. Moving to the big block would be a much better option if you wanted more power. You're gonna spend more money than the bigger block costs to get in the same realm of power. It just ain't worth it...
Thu Jun 20, 2013 9:26 pm
Post Re: 23 or 25
Fuck bps! :lol: Think outside the box! Don't follow the crowd! :lol:
Thu Jun 20, 2013 9:34 pm
Post Re: 23 or 25
Nope, I've answered those questions probably 100 times. I'm done with it... They can search through the forum or figure it out on their own! :lol:
Thu Jun 20, 2013 9:39 pm
Post Re: 23 or 25
Toughen up Nancy! :lol:
Thu Jun 20, 2013 9:42 pm
Post Re: 23 or 25
Fri Jun 21, 2013 7:41 am
Post Re: 23 or 25
I am going to gamble that in the not so far off future, some company is going to build a four stroke motor from the ground up that is intended for mud motors.
I am not a small engine mechanic or expert, but there is a significant difference in a motor designed for a lawn mower/ lawn tractor, vs. a performance motor designed for a ATV, motorcycle, or other performance machine.
I am not suggesting that as motorcycle engine would do better on a mudmotor, but I am guessing that building a motor from the ground up, that is intended for a mud motor, is going to focus on the right compression, RPM range, weight, angle,shaft position, throttle response, and a whole lot of other factors that in the long run will work better than a motor that was originally designed for a lawn tractor or rototiller.
I would bet that if a company like Honda set out with the intention of designing the engine, frame, prop, shaft, and entire package, that the mud motor would evolve very quickly when high end engineers put their two cents in.
Uncle J 18x54
Fri Jun 21, 2013 8:00 am
Post Re: 23 or 25
Fri Jun 21, 2013 8:11 am
Post Re: 23 or 25
Fri Jun 21, 2013 8:15 am
Post Re: 23 or 25
Fri Jun 21, 2013 9:19 am
Post Re: 23 or 25
Take it to rob. I don't work on much shit for other people. :lol:
Fri Jun 21, 2013 11:53 am
Users browsing this forum: No registered users and 42 guests
