It is currently Mon Jun 30, 2025 8:16 am
Reply to topic  [ 11 posts ]
 May be a dumb question about pods
Post May be a dumb question about pods
Testing my boat tomorrow with the backh20 pods on. Do you guys ever have problems with logs knocking the plugs out of them. I can just picture going slow over a stump and sheering one of them off.
23 swomp/ 1542 tracker
Tue Aug 13, 2013 10:46 am
Post Re: May be a dumb question about pods
Find a drive that will fit on the inside and turn the plug inside/out. Problem solved!! Brilliant!!! :D
Tue Aug 13, 2013 1:32 pm
I don't get it
Tue Aug 13, 2013 2:17 pm
are your drain holes for your boat going threw your pods?
Tue Aug 13, 2013 2:20 pm
If you can put your plug in from the inside of the boat.
Tue Aug 13, 2013 2:27 pm
No I can't put them in from the inside. They are aftermarket and I welded them on. I am half tempted to thread them so I can screw a plug in. I have one drain hold and that is back center of boat. It is a pos riveted tracker not a costum
Tue Aug 13, 2013 3:10 pm
I have rubber plugs and have never had issue. You could buy this type of plug (below), the tab bends down, unlikely to get knocked out.
http://www.cheaperthandirt.net/product/ ... 4AodXzwAtA
Wed Aug 14, 2013 11:10 am
Tap and plug them is the way to go did that to my first set. the plugs either got knocked out or just leaked.
Wed Aug 14, 2013 11:42 pm
Measure the hole and get an expandable rubber freeze plug from a parts store. No edges/handles or lock tabs to snag and get pulled out, just a 7/16 nut to loosen to pop it out if you need to drain them.
Tue Sep 03, 2013 9:56 pm
Thanks for the replies. I had the 3rd one knocked out this morning when I was scouting. I called Arlen at backh2o. That guy is a plethora of knowledge. He said cork will work. So that's that I guess. Covered up in blue wings up here. They are making there way down to you guys.
Wed Sep 04, 2013 11:07 am
Users browsing this forum: Google [Bot] and 40 guests
