It is currently Mon Jun 30, 2025 1:48 pm
Reply to topic  [ 14 posts ]
 What else fits?
Post What else fits?
I currently have a Carrol Stream 9hp long tail and thinking about upgrading if I get a new boat. With that design, what upgraded motor can I get that will bolt up the same?
Sun Sep 01, 2013 8:52 pm
Post Re: What else fits?
Are you looking for more HP? did you try calling Carrol stream motors and see what they have that might bolt to your frame.
Sun Sep 01, 2013 9:24 pm
Yea I want about 13+ hp. I'm new to these motors so not exactly sure what to look for. It doesn't have to be a Carrol motor, just need more hp.
Sun Sep 01, 2013 9:39 pm
I called Carrol Stream about a motor for a home build i'm starting. they told me all of their motors have the same bolt pattern so if you stuck with the Carrol Stream motor it should be a direct fit and a easy fix to change motors to a larger size.
Wed Sep 04, 2013 9:30 pm
Also gotta figure for similar pto shaft heights
1436 Lowe
Wed Sep 04, 2013 11:35 pm
Nobody picked up so I emailed them.. anyone care to look over these two and see if you think they will match up?
this is what I have..
http://www.carrollstream.com/9HP_Gas_En ... cs177b.htm
this is what I want..
http://www.carrollstream.com/13HP_Gas_E ... s188es.htm
Thu Sep 05, 2013 9:08 am
I just got an email back.. no other Carroll motors will match up!!
What do I do ???????!!!!!!!!!!!!!!
Thu Sep 05, 2013 2:21 pm
1. Go to Maxtool.com
2. Order 16hp engine
3. Put new engine on frame, take measurements
4. Make necessary changes (drill new holes, cut/ reweld frame)
5. Reassemble longtail
6. Take your boat out and plow through some mud
(Don't forget a 8x4 prop if you dont have one already)
1436 Lowe
Thu Sep 05, 2013 2:26 pm
1. Tell wife you have a rare investment opportunity. 2. Go to bank and withdraw $2500. 3. Buy a bad ass mud motor. 4. Tell wife investment was a bust. 5. If wife asks why were you so stupid to loose the money tell her stfu. 6. If she persists kill her and chop her body into little pieces and disperse them in the swamp using you new badass mud motor. Sounds like a winner. :twisted:
23 swomp/ 1542 tracker
Thu Sep 05, 2013 3:42 pm
LMAO!
2008 23hp GDSD w/ BPS crossover, Mikuni carb, and Big Blade prop pushing a 2008 16x48 GDSD boat.
Thu Sep 05, 2013 4:40 pm
Fri Sep 06, 2013 5:43 am
What kinda "bad ass mudmotor" you gonna buy with $2500? Dixie?
Fri Sep 06, 2013 8:33 am
Fri Sep 06, 2013 1:51 pm
Users browsing this forum: No registered users and 46 guests
