1chance
Joined: Sun Jan 25, 2015 12:10 pm Posts: 55 Location: Kentucky lake-big bear highway
 10" prop on small block
Anyone ever try a 10" diameter on a small block? If so, what was your experience? I am thinking I can get better push in the mud with a 10" prop.
I have a 24 honda with tuned exhaust, jetted and throttle advanced to 4200 out of water.
Thank in advance for any help fellas.
_________________ 18x50 DFOU custom hull, backwater kit with gx670 honda, Robertson exhaust kit, Work in progress
Sat Jul 30, 2016 5:20 pm |
brycecheramie
 Re: 10" prop on small block
the big blade comes on the 23 mudbuddy's I think.
Sat Jul 30, 2016 5:23 pm |
huck Finn
Joined: Thu Jan 31, 2013 5:42 pm Posts: 1913 Location: Conroe tx
I ran a 10x 5 all season , pushed better and nastier in the mud . With that bring said the. 9x8 is faster in my rig . I plan on puttin the. 10 x5 on come sept.
H Finn
_________________ Ole black water keep on rolling
18x54 Uncle J -GTR - with the koolaid Back H2o SWOMP 23 SS stage 2 15x36 GD Duck Skiff GATOR GATOR GLIDE PROSTAFF BACKWATER PROSTAFF http://www.gatorglide.com
Coupe rest in peace brother
Sat Jul 30, 2016 7:09 pm |
Russ
Surface drive or longtail? Bryce is talking about on an sd, and huck is talking about a modded longtail. Two different prop concepts work on each.
Sat Jul 30, 2016 7:39 pm |
Will C
Its in lontail talk, i kind of thought is was a longtail
Sat Jul 30, 2016 8:16 pm |
BERNIE255
Joined: Sun Jun 16, 2013 4:43 pm Posts: 1381 Location: Avoyelles Parish/ Marksville LA
Tuned exhaust?
Sat Jul 30, 2016 8:44 pm |
brycecheramie
Sat Jul 30, 2016 8:58 pm |
Russ
Never looked at the section. Thanks will lol
Sat Jul 30, 2016 9:07 pm |
Russ
So listen to huck, ignore bryce.
Will C
Sat Jul 30, 2016 9:16 pm |
cb5331
Wait, someone posted in the correct section?
Sat Jul 30, 2016 9:17 pm |
Russ
Caught me off guard too, cb. Lol
Sat Jul 30, 2016 9:22 pm |
brycecheramie
Yeah, im used to people posting in any section they feel fit OP, your motor will need some nuts to turn a 10" prop.
Sun Jul 31, 2016 12:05 am |
cb5331
Sun Jul 31, 2016 7:46 am |
Glades Ranger
Joined: Mon Sep 19, 2011 6:32 pm Posts: 1490 Location: south Florida
Huck, what kind of rpms are you running with the 9x8 and 10x5 (with the modded 23 right?)? Other than tweaking the throttle, I've never done any mods on my LT's. Both my 9x7 and 9x6 are almost the same with my 26.5 BW. I figure I will lose a lot of rpms if I try a 9x8.
_________________ Sailing in the sawgrass /1648 grizzly and Swomp 26.5 EFI
Sun Jul 31, 2016 7:48 am |
SETx Longtail
Joined: Sun Sep 01, 2013 2:53 pm Posts: 3480 Location: Hardin County, Tx
Last I checked, he's running all the RPM.... Lol. That skiff of his will hang with my rig thru the woods. It's impressive.
_________________ #CFFITR
-Custom pool noodle -stage 4 water wings
Sun Jul 31, 2016 8:11 am |
huck Finn
Sun Jul 31, 2016 8:46 am |
brycecheramie
 Re: 10
Sun Jul 31, 2016 7:42 pm |
1chance
 Re: 10
[quote="BERNIE255"]Tuned exhaust?
30" primaries into a y then single muffler. I have pics if you would like to see what I am talking about. Jetted carb to match exhaust, and picked up a substantial amount of power compared to boring stock motor.
Mon Aug 01, 2016 9:43 pm |
1chance
Huck,
What all is involved in your stage 2? What kind of speeds were you getting from you 10x5 vs 9" prop?
Mon Aug 01, 2016 9:47 pm |
huck Finn
I mean the 10x 5 was still running 24 mph . The 9x8 averages 26 or so. It's heads by setx performance , now nick and Cody . 34mm round slide , rejetted a little on the rich side to run that fast. Cam is a Cody cam ,setx . Exhaust is a bps crossover , been cut and reworked , welded hopefully to last longer . This motor is very stout . And the power to weight ratio to my rig is perfect . You can cruise with the big blocks and drive like a hot rod in the mess.
H Finn
Tue Aug 02, 2016 6:31 am |
1chance
Thanks for the info Huck. How well do you think a stock 23/24 would turn a 10x5? I have been looking at ways to get more thrust in the Kentucky silt/clay mix down here. I can turn 9x6 prop no problem at all, but was uncertain about how much harder the 10" blades would be to turn. Maybe a good reason/excuse to upgrade the carb.
Tue Aug 02, 2016 10:30 am |
SETx Longtail
I'd try to just step up a little pitch before I tried more diameter, especially since the engine is stock still. If you're wanting more thrust thru the junk, try adding more cup to your existing prop.
Tue Aug 02, 2016 10:34 am |
huck Finn
Not very well , too much prop for a stock motor . For example the 9x8 and 10x5 are rated for the 37 efi block. I probably have a 9x 7 you can try for free. Pm me. One pitch change is a couple hundred rpms different for me.
H Finn
Tue Aug 02, 2016 10:36 am |
1chance
Thanks for the offer on the 9x7. Currently I have my outboard on my rig, but I usually put my long tail back on in September. I am just trying to be proactive and get thing sorted out before the season gets here. I might just send my prop to Hopkins and get it cupped and pitched.
Tue Aug 02, 2016 10:58 am |
