It is currently Sun Dec 21, 2025 10:27 am
Reply to topic  [ 5 posts ]
 First post, LT question
Post First post, LT question
Hi folks new here, how is everyone?
So I've been searching for a while and I have a question.
There's a bit of dead horse beating so bear with me.
I'm purchasing a long tail go devil from my stepdad, it's an older model that came with an 8hp engine.
Engine went bad they swapped it for a 5hp Briggs while getting the 8hp rebuilt.
I'm getting the go devil plus both engines for a steal, obviously I plan to run the 8hp then later upgrade to a 13hp. I spoke
With a go devil rep that said that was the biggest engine I could mount on the frame. Yeah it's only 13hp but whatever it's better than what I have now.
My question is boat size.. I'm a large fellow about 280lbs
Gear, a friend, kids etc. I want a boat that the 8hp will surfice until the 13hp upgrade.
I'm thinking maybe a 1440? Would it be much difference between that and a 1540? I hunt mostly small rivers, flooded timer, creeks, and backwaters.
Opinions, advice, experience welcome.
Of course if I can squeeze more hp on it by all means chime in!
I'm sure I'll probably have to upgrade props as well?
Thanks all!
Sun Dec 28, 2014 9:36 am
Post Re: First post, LT question
Congratulations on your longtail, I would buy a 1542 tracker. Only 200# and should float you and your family safely. Good luck.
Sun Dec 28, 2014 5:48 pm
Get the bigger boat because you can always upgrade the motor if you choose too. Yes it will be slow but its better than paddling. I started out with an 11 hp and you could walk as fast as the motor pushed the boat. It beats walking!
Sun Dec 28, 2014 8:16 pm
Thanks for the replies! I'm 100% thinking at least a 1540. Not sure on engine yet, maybe Honda maybe predator, With a 8x4 prop? I'll probably do air fuel mods but that's about the extent of it.
Mon Dec 29, 2014 7:13 pm
1440 maybe 1542 if you plan to get a 13hp. i have a predator 212 on my 1436 and i get by just as fast as my 8hp yamaha
Tue Dec 30, 2014 10:36 am
