It is currently Fri Jun 27, 2025 4:27 am
Reply to topic  [ 15 posts ]
 Long tail shaft wont turn?
Post Long tail shaft wont turn?
Went out to hunt this morning, motor has been running flawless since i got it for the most part... Warmed my engine up.. Got in the boat went to start it up again and the shaft wouldn't budge? Is there a bearing in there i can take out and replace? New to the long tails and know nothing about them... Any help and or step by step instructions would be greatly appreciated! ... It is a KKK thai long tail kit .
I need to get back out to my honey hole!!!
Thu Jan 15, 2015 5:35 am
Post Re: Long tail shaft wont turn?
KKK brand :)
Thu Jan 15, 2015 12:15 pm
So the prop wont turn but your engine runs? Means your coupler isn't connected to your shaft. If it was your engine wouldn't run. If so make sure engine is off and loosen the coupler wing nuts where the shaft comes out. Go to your prop and try to push the shaft back into the engine while you rotate your prop. If you feel the shaft slide up into the coupler, retighten those wing nuts and try and start it again.
Thu Jan 15, 2015 1:07 pm
need more info on what's going on.
Pull start or electric start?
Does the engine turn over?
If nothing spins, engine or prop your either seized a bearing/bushing in the tail assembly or the engine seized up after you shut it down. I'm not familiar with the brand you are running, but I assume the tail shaft would be rebuild able if needed.
Thu Jan 15, 2015 1:21 pm
Took the coupler off, engine turns freely, the shaft still would not turn, the bushing down by the prop (picture attached) looked melted and when i removed that the shaft turns good now, i just do not know where i can get a new one? Or even a better one?
Thu Jan 15, 2015 2:14 pm
Find a brass one. It won't seize
17*38 Klibert 23GDLT
Thu Jan 15, 2015 3:30 pm
Where can i find a brass one???
Thu Jan 15, 2015 5:35 pm
Machine shop....have it made.
Thu Jan 15, 2015 6:29 pm
Thanks ill look into that! Was kinda looking for a right now fix too? So i can finish season off :) any place i can get just a replacement??
Thu Jan 15, 2015 9:08 pm
Put some grease in the damn thing and run it if you want to hunt. Or call the slant eyed f'er you got it from and get his best solution.
Jennings1977 wrote:
Way to chime in there buddy. Ill let you gobble my wiener to since you asked. You really got me with that comment. What are you about 18 yrs old tryin to fit in where you don't? You guys are some of the biggest egotistical bunch of pricks I've ever seen. Lol shut the f&$k up and get back on momma's tit.
Thu Jan 15, 2015 9:16 pm
Go to mudmotorkit.com they have the part. give em a call if you don't know your serial number.
Fri Jan 16, 2015 7:21 am
Thanks for the help
Fri Jan 16, 2015 9:09 am
Greased the hell outa the old one and seems to be fine! Hopefully it will hold up for tomorrows hunt.
Fri Jan 16, 2015 11:45 am
R u running/warming up your longtail out of the water for a long time?
Fri Jan 16, 2015 2:37 pm
Not usually, today i ran it for about 10 min outa the water but i was spraying a hose on it to keep it cool and it seemed to work well
Fri Jan 16, 2015 8:00 pm
Users browsing this forum: No registered users and 41 guests
