It is currently Fri Dec 19, 2025 5:24 am
Reply to topic  [ 11 posts ]
 backwater bearings size
Post backwater bearings size
The shaft worked up through the ujoint and the back prop nut went into the bearing housing tearing out the seal and grinding on a bearing. I don't want to wait for an order from backwater. I got hunting to do. Anyone know the bearing dimensions? I'm assuming they are standard. I can get bearings and seals from my local napa if i give them a size. Help would be surely appreciated !! It's the weld on rear housing. What a bunch of squeeling, grinding, and vibration! I thought the universal was going out at the time.
Tue Oct 20, 2015 7:45 pm
Post Re: backwater bearings size
You should probably call the guys at backwater....
Tue Oct 20, 2015 8:36 pm
I just thought there might be some hands on mudders on this forum.
Wed Oct 21, 2015 6:24 am
Call and ask backwater the bearing dimensions. They'll probably tell you.
Wed Oct 21, 2015 11:10 am
NAPA- Bearings yes, seals no. Give Backwater a call. They will overnight them to you. Some of the best customer service in the business.....use it.
Wed Oct 21, 2015 11:20 am
Do you have a Backwater frame or just their bearing set up? Can you please post a picture of what happened? Thanks.
Wed Oct 21, 2015 1:39 pm
I really can't imagine how the prop nut got to the bearing. Once again, please post pics if you don't mind.
Wed Oct 21, 2015 4:20 pm
I'll have one of my boys post pics as soon as I can. My phone doesn't send pictures for some reason. I didn't know they overnighted stuff. great. I've been putting a shift kit in the truck the last 2 days. Yanking bearings tommorrow if it don't rain. And not a BW frame. :oops:
Bog Hog tube and shaft.
Wed Oct 21, 2015 5:44 pm
You're saying the first prop nut tore up the bearing housing cap and then wrecked the seals and bearings?
Wed Oct 21, 2015 8:54 pm
I'm pretty sure that your Bog Hog has bronze bushings.
If there is not much play in the shaft, you should be ok with just replacing the seal for now.
Thu Oct 22, 2015 8:56 am
I'm sorry I didn't clarify.. Bog hog with the old style Backwater weld on bearing housing kit.
No tapered ends on the old style. And I beefed the frame up with struts on the top and 2 sides, and a few gussets.
Shaft is out. Crap! Grooved out where the bearings rode. Hafta build them up and take the shaft to a machine shop. After I get the seized prop off so I can slide the housing off.
Wondering now why I didn't go with the Bog Hog bronze bushings instead of going with the bearing route. Not knocking BackH2o. Heavy duty stuff.
It would have just been a heck of an easier, cheaper fix! Puddle jumping now.
Pictures will be coming.
Thu Oct 22, 2015 12:57 pm
