It is currently Tue Jul 15, 2025 10:29 pm
[ 6 posts ] |
Prop ? for a 27 LT on an Aucoin 18x48
JpEater
Joined: Tue Sep 22, 2009 8:02 pm Posts: 245 Location: Augusta, Ga.
I have a 27 Kohler LT on an Aucoin 18x48. I just put it in the water for the first time yesterday. I could only muster 3100 RPM out of the motor. I am assuming that the motor has a 9x7 prop on it now. Does anyone run a similar setup? If so what prop are you/ should I be running. Motor runs ok but I am going to do a compression check tomorow. Just doesn't seem to build the RPM's the it needs to. It was just me (160lbs), 5 gal gas, a few life jackets, one group 24 battery, and one fire extinquisher. Not much of a load at all.
Trey
_________________ Aucoin 18'x48'' Bateau, 30hp GD Longtail.
Wed Dec 23, 2009 9:37 am |
JpEater
 Re: Prop ? for a 27 LT on an Aucoin 18x48
No one has an idea?
Wed Dec 23, 2009 12:17 pm |
kibb
Joined: Wed Jan 14, 2009 8:58 pm Posts: 2731 Location: Lafayette, LA
Whats your OOW rpms?
_________________ 1644 WeldCraft / 27 GDLT Ranger R71 / 125 Merc
Wed Dec 23, 2009 6:49 pm |
Gigafowl
On the 23 GDLT in my 16x48 GDSD hull the best prop was the 9x6 - for 2 man loads and all around performance @ 21 mph solo and 19 mph loaded.... The 9x7 was 2 mph faster solo and empty but was 2 mph slower with 2 man hunting load @ 23 mph solo and 17 mph loaded...
If you remove your prop the pitch should be stamped into the hub - if you measure from tip to tip and have less than 8 1/2 inches - it is time to consider buying a new prop....
Dropping one pitch will add about 300 rpm at WOT and a lot more bottom end power.... Each pitch change is drastic with these longtails - some get best perforance and speed with the 9x5...
Wed Dec 23, 2009 6:52 pm |
JpEater
I will pull the prop and look at the pitch stamped on it. It is a MB prop on a GD. I don't know the OUt of water RPM's. I know they are WAY high. The PO has messed with the governer to the point that it does nothing out of water. It will hit 4k at half throttle. I am going to work on it some more tomorrow. Got a serious crank case leak that has to be fixed too.
Wed Dec 23, 2009 7:36 pm |
dead duk
Joined: Thu Jun 25, 2009 10:45 am Posts: 147 Location: Longview,Texas
JP....I have a 27 mudbuddy on a 15x48 duracraft and I get the following with a brand new prop....
4050 RPM's out of water 3050 RPM's with a load of 2 people and 3 doz. decoys.
I am ok with the performance knowing that the motor is a little too big for the boat. I just put a new prop on the motor in between the splits in LA. I explained my situation to mudbuddy and they still recommended a 9x7 for my setup. Still not quite sure about the answer I got. I am still under the opinion that 9x6 would have been better for me.
Thu Jan 07, 2010 12:38 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 57 guests |
