It is currently Sat Aug 02, 2025 4:52 am
Reply to topic  [ 3 posts ]
 MB 45 hard turning
Post MB 45 hard turning
On my new MB 45 it turns like a dream to the right but you realy have to fight it to turn to the left I assume that I need to bend the skeg a little bit but not shure on which way to go any opinions?
Sat Jul 10, 2010 12:54 pm
Post Re: MB 45 hard turning
Sounds like if it is easy to turn to the startboard side, then you skeg is probably bent towards the port side. Bend it slightly in the direction of the starboard side and see what happends. One question, when you are driving straight, does it feel like it was to turn to the right (i.e. is it trying to pull the handle toward the port side of the boat)?
One other thing to check would be your weight distribution in the boat. That can always affect the way it turns one way or another.
1644 Go-Devil
2008 23 GDSD
Sat Jul 10, 2010 1:35 pm
Is your motor mounted in the center? Its best to mount it 1" to the port side and adjusting from there (may move a little either way to remove torque). Also, as stated above, imbalanced weight distribution can cause alot of tiller torque.
Bending the skeg is the last resort- not the place to start.
Sat Jul 10, 2010 5:07 pm
Users browsing this forum: No registered users and 90 guests
