It is currently Tue Jul 29, 2025 7:08 am
Reply to topic  [ 13 posts ]
 Relocating PD trim switch to grab bar
Post Relocating PD trim switch to grab bar
I know a few of yall have done it..... What's involved? There is a red,blue,yellow black wire running into the original switch. Anyone got any pics on how they did it? Thanks.
WC Custom 1854
Fri Sep 24, 2010 8:09 pm
Post Re: Relocating PD trim switch to grab bar
Fri Sep 24, 2010 8:35 pm
if it has relays it's not necessary to upsize the wires. there wont be any load on the switch.
1554 excel- custom MB sport totin a stage II generac temporarily
20XRD Bullet- 300X Merc
Sat Sep 25, 2010 12:16 pm
Sat Sep 25, 2010 2:12 pm
No relays on the PD trim switch...use the bigger wires.
1848 Brother w/ 36 PD
Sat Sep 25, 2010 10:59 pm
thats weird to not have relays with that much current :? better use a good switch
Sun Sep 26, 2010 7:12 am
FWIW, it's a old style winch trim. Where would I find a good switch?
WC Custom 1854
Sun Sep 26, 2010 10:28 am
Get a switch from pd...or you can use a rocker switch off of an atv winch...they should be the same (I think tractor supply carries them). I believe they are rated for 75 amps. GT use to use relays, but had too many problems with them and changed over to these rocker switches.
Sun Sep 26, 2010 4:59 pm
atv dealers have em in stock too.
Sun Sep 26, 2010 7:37 pm
u cant do it on winch trim without a relay. u can do it on the hydro trim tho.
ive had both
Mon Sep 27, 2010 8:44 pm
Profile YIM WWW
Well, I put a warn switch to the grab bar with the warn relay. 2 wires from the relay going to the winch and two wires going to the battery. When I do it this way, I cannot use the original winch trim switch (starts smoking). But as soon as I disconnect the original wires from the winch, it works flawlessly with the new switch on the grab bar....
I guess it's an either/or deal where I cannot use both?????
BTW, it's kick ass having it mounted on the grab bar!
WC Custom 1854
Tue Sep 28, 2010 11:31 am
Any reason you cant just use a Transom Tilt Switch like from bay boat or something
Tue Sep 28, 2010 3:54 pm
Tue Sep 28, 2010 5:03 pm
Users browsing this forum: No registered users and 118 guests
