It is currently Sun Jul 13, 2025 9:05 pm
Reply to topic  [ 16 posts ]
 what causes this
Post what causes this
16hp briggs to spit and sputter wen u get on it?
Thu Oct 07, 2010 6:35 pm
Post Re: what causes this
bad gas. dirty carb maybe
Thu Oct 07, 2010 6:36 pm
dirty carb my guess
14 by 44 Weld Craft powered by a 20hp. go devil longtail
Team Arc Angel Bowfishing
Thu Oct 07, 2010 6:37 pm
needs carb cleaned. not just wit spray, totally disassembled and cleaned thoroughly
wat would it cost at a lawnmower shop to do it bc i have no clue hom to mess with that
Thu Oct 07, 2010 6:40 pm
the one where i live (gonzales la) is 45 an hour
Thu Oct 07, 2010 6:44 pm
dam i juss dont trust maself taking it apart and putting it back together
Thu Oct 07, 2010 6:45 pm
the dissasembly/assembly part is actually very easy. its making sure the air/fuel mixture screw is set correctly and then adjusting proper idle speed.
Thu Oct 07, 2010 6:47 pm
do u do that whie the carb is on or off? the adjusting
Thu Oct 07, 2010 6:50 pm
with the fuel mixture screw, after you remove the carb, tighten and LIGHTLY seat the screw, while counting how many turns it took to get there. when you reassemble, put the screw all the way back in, then back it out to where it was before. and you do that off of the boat, you shouldnt have to mess wit it after reinstalling the carb if you got it right. the idle screw can actually prolly be left in place. the main thing is that you wanna remove the jets, o rings and gaskets. the orings and gaskets will be ate up from the cleaner. i buy the cleaner in a gallon from oreilly auto, it has concise instructions on the label, it works great
Thu Oct 07, 2010 6:55 pm
alright ill take a look at it tomorrow thanks man for all the help
Thu Oct 07, 2010 7:17 pm
no prob bud. btw, i buy a service manual for everything i have that has an engine. the factory manual will explain everything in detail. any lawnmower shop can get you one
Thu Oct 07, 2010 7:19 pm
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Thu Oct 07, 2010 7:21 pm
iight ima check it out next time i go..................x2?
Thu Oct 07, 2010 7:28 pm
that means i agree
Thu Oct 07, 2010 7:30 pm
oh ok lol i was lost for a sec
Thu Oct 07, 2010 7:35 pm
Users browsing this forum: No registered users and 55 guests
