It is currently Fri Dec 19, 2025 11:33 am
Reply to topic  [ 163 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 How To Build Two HID Lights For Under $100
Post Re: How To Build Two HID Lights For Under $100
k...thanks Chico
1850 & 36pd
Thu Oct 14, 2010 10:45 pm
Guys,
Chico has been great help on this and I'm running with his idea. I just wanted to let y'all know that I just ordered the Vision X 5511 and 5512 which are the round lights. One will be a spot beam and the other a flood beam. I ordered one of each for a pair of swamp lights. I plan on plugging them into my trolling motor via the plug and putting an inline on/off switch after the HID bulb upgrade.
The company on the link was out of one of the lights so I ordered through vision x superstore. I had to pay $10 bucks in shipping though.
Thanks again Chico.
Mon Oct 18, 2010 4:55 pm
I had the same idea for power, just using my trolling motor wire and installing a switch to control them. I'm fixing to order this setup as we speak.
Mon Oct 18, 2010 10:54 pm
I had a chance to try the boat and lights out this morning before sunrise and they were a 500% improvement! The problem I was having before is that either I'm color blind or the yellow light was blending in with the yellow saw grass I run in and I couldn't see anything. Now with the white light, I can clearly see about 200 yards or so clearly.
I've only had this boat for about a month and was previously running an outboard so I had to pretty much stick to the main canals in the Everglades making it very hard to get lost. Well it's a completely different ball game with a mud motor since I can go right down the middle of the swamp now and the first night I took it out during early teal season, I got stuck so bad I thought I was going to have to call 911 and get air lifted out of there because I couldn't see where I was going. Luckily after an hour of pushing, my friend and I freed the boat and I think that's how this idea came about.
"We Are Products Of Our Decisions"
Wed Oct 20, 2010 7:16 pm
Guys, BayouStateHunter tried using the Vision X 5511 and 5512 lights and they did not work with the H3 bulbs. From what I can tell, they require a D2 type bulb that needs to be retrofitted by buying a socket to plug the light in. He'll chime in on this later on but I think he ended up returning the round lights and going with the square ones. So if you intend to do this upgrade, just stick with the original square lights and they'll work as described. Thanks Bayou.
Mon Nov 08, 2010 8:59 pm
Tue Nov 09, 2010 7:58 pm
Don't mean to keep beating a dead horse but I built my second set of lights today and I did it in half the time as the first set. Unfortunately I didn't take any pictures but you should be able to understand what I mean by looking at the original ones I posted. To speed things up when using a dremel, just cut a ring completely around the inside base on the light housing with the exception of the bottom part where the ring comes in contact with the housing. Then cut clean through the two plastic square molding located at each end of the housing but do so at the same height as the plastic ring that needs to come out. Finally just cut the plastic molds out with wire cutters and everything will come out in less than a minute and look a lot cleaner. It now took me about 20 minutes to make both lights. I also used the spot beam lights for this set and the beam pattern is not as focused as one would expect so they'll still be able to light up objects completely that are at a close range.
Thu Nov 11, 2010 5:46 pm
marked x2!
Thu Nov 11, 2010 10:13 pm
I finally finished my lights and they are bright. I went with one flood and one eurobeam. One bit of advice I have is don't buy from the Vision X superstore. They forgot to send my order out, that's why the install took so long and didn't help me out with the shipping even though it was there error. I plan on running with these Friday morning. Thanks again Chico.
Wed Nov 24, 2010 10:38 pm
1648 Tracker 50 Merc
Team Topwater-Alabama
Thu Nov 25, 2010 9:52 am
I built a couple using just the VX floods. It was the best $100 bucks I've spent on the boat this year. They really light the way projecting out front and to the sides. Thanks Chico80x
Tue Nov 30, 2010 11:48 am
Thanks koondog, glad you're happy with them! Enjoy.
Tue Nov 30, 2010 3:11 pm
Just pulled the trigger on a eurobeam and a flood with the Hid kit for my gatortrax. Can't wait till they get here.
Wed Dec 01, 2010 9:19 am
So what would you guys recommend for this set up, one driving beam and one flood beam, or both of one kind?
1848 Brother Breaux
36 hp Pro Drive FPR
Mon Dec 06, 2010 8:27 am
I think you could get any combination and be happy. I have two euro beams and they work great, plenty of forward lighting with very good side lighting. I put two spot beams on my buddies boat and they too work great, I think he was a little more range than me on the lighting but overall there is very little difference between my beam pattern and his.
If I had to do it again though, I would probably go with one spot mean and one horizontal flood beam to get the best of both worlds but since I haven't seen the beam pattern on this set up yet, I couldn't tell you for sure. Either way, I'm very happy with my two euro beam set up and it was a huge improvement.
Mon Dec 06, 2010 10:46 am
thanks for the info, i was kinda leaning toward one of each too
1848 Brother Breaux
36 hp Pro Drive FPR
Mon Dec 06, 2010 12:00 pm
Mon Dec 06, 2010 5:51 pm
I too have been very disappointed with my gator trax lights. I put a go light on top of the bar and the other two have been useless. I plan on trying to order these. Thanks for the info.
Bayou Gun Runner
Tue Dec 07, 2010 8:50 pm
ight orderd mine so ill post up how it goes when i get everything in
Sun Dec 12, 2010 3:38 pm
I run two floods. You'd be surprised how far forward and wide the light casts. You will not be disappointed.
Mon Dec 13, 2010 2:38 pm
I did the flood and eurobeam combo. It works great. Anybody who does this upgrade will be happy with it.
Tue Dec 14, 2010 7:47 am
Here's some instructions on how to do it to a set of Hella 500s that you can get at Wal Mart.
http://www.tacomaworld.com/forum/lighti ... -pics.html
Wed Dec 15, 2010 12:08 am
Wed Dec 15, 2010 5:45 pm
orderd all my stuff on sunday
recived my bulbs yesterday
as far as the lights go i got an incorrect tracking number and they were quick to reply with the correct tracking number and they will be here on the 20th
Thu Dec 16, 2010 3:12 pm
Holy shiat man these things are bright
Thanks for the post these are 200% brighter
Mon Dec 20, 2010 4:46 pm
I just finished my pair. I bought the euro beams. They are BRIGHT!!
I can't get my bulbs to stay straight in my reflectors. They are being pushed to the side by the ballast. I have all the inside plastic cut out and still cant seem to get it to fit just right. Anyone else have this problem? They work fine, the beams are just a little distorted since the bulbs are not centered on the reflector.
Wed Dec 22, 2010 6:36 pm
by the way.....great post! and thanks!
Fitting the ballast in there correctly takes a couple of tries to get it just right. The main thing is to find a way to position it so that there's as little pressure as possible on the back of the bulbs but it will still be a tight fit. One thing you should make sure of is that the tab on the back of the reflector is a tight fit along with the screw.
One thing I did on mine to position them better is that instead of putting the ballast flush against the back of the light housing, I put it at an angle with one end of the ballast up against the reflector and the other against the back of the housing. Then position all the wires around the ballast so that there are no wires between the ballast and the bulb to keep any pressure down to a minimum. Hope this helps.
Wed Dec 22, 2010 7:02 pm
Here is an web address that has lots of LED lights some of which are not to expensive.
http://www.magnalight.com/.
Wed Dec 22, 2010 9:12 pm
Not a big deal but after the bulbs warm up one light seem brighter than the other
They are still bright as hell but just a question
Thu Dec 23, 2010 12:38 pm
Chico80x how do those hid's do in thick fog ?
I have HIDS in my trucks but none have them in the fog lights.
btw this a very helpful post. Unfortunately i already spend the big bucks on the KC version but im gunna build me a set for my duck boat!
Sat Dec 25, 2010 1:14 pm
These lights did good in the thick fog I was in the other day but I had to aim them down because they lite the fog up too much. The fog I was in was so thick that I couldn't see more than 30ft in front of me regardless of the lights but when they were aimed up, it looked like if I was in a white cloud. It was too dangerous to bring the boat up on plane in those conditions.
Sat Dec 25, 2010 1:34 pm
Well I was going to try building these But, I went to Napa instead. they had these for 16.00 each and the housing is all rubber. I went ahead and paid another 17.00ea for a different bulb. the guy said they use these bulbs for spotlights on airplanes... Will see how bright they are but they are already better than the ones I bought from Gator Trax. Total cost was 60.00 and thats having two extra bulbs
Bayou Gun Runner
Mon Jan 17, 2011 6:03 pm
Have you got to try out these lights yet?
Thu Jan 20, 2011 6:31 pm
Just at my house but I live in a subdivision. I can still see the beam on my neighbors roof though. I put one of the airplane bulbs in today so Im gonna see which is better. Im going hunting Saturday so I will put them to the real test then and will let yall know.
Bayou Gun Runner
Thu Jan 20, 2011 7:18 pm
Ok so I ran the boat yesterday. The lights were awesome on the actual canal, brighter than my GO light. Once we got into the bay they got kinda lost if that makes since. I think they may need to be pointed down. Unfortuntely I got stuck and it took me almost two hours to get out so I didnt do that.
Bayou Gun Runner
Sun Jan 23, 2011 9:35 am
Have any of you guys that have built these HID lights had any issues with them? I used mine all season long and didn't have a single issue but for some reason, one of the handheld spot lights I built quit working, I think it's a bad connection but haven't opened it up to find out.
Overall, I would have to say that this was the best addition I made to my boat this year and I just wish I would've done it sooner since it made navigating in the Everglades that much easier for me.
Wed Feb 02, 2011 10:06 pm
http://www.ddmtuning.com/Products/Apexc ... or-HID-Kit
$30 HID kit. That where I ordered mine from for my truck and my motorcycle. They work great, haven't had a single problem with them. I belive they come with a lifetime warranty as well.
Sorry if someone already said something about these, I didn't read through all the posts. Just wanted to share because this is the cheapest place I know to by an HID kit.
Thu Feb 03, 2011 1:21 pm
Guys, a member here was trying to buy the parts on the links I provided and ran into some confusion and I'd like to clarify it for anyone attempting this in the future. On the site that you purchase the actual light housings (not the bulbs which is ebay), it'll ask you for the MAKE, MODEL, AND YEAR, of the vehicle you want to put these lights on. Just input whatever you want there because you are buying a generic part that will fit any vehicle so it doesn't matter vehicle these are going in.
Also, the links to the parts listed in the previous posts ARE THE SAME EXACT PARTS I USED FROM THE SAME VENDORS. I was also asked what I would rate the difficulty as from a 1 to a 10. If you have a dremel, I would say building these lights is a 3 at the most. No dremel, a 5 just because of all the cutting involved. Very easy and worth it in my opinion.
Tue Mar 22, 2011 8:00 pm
The Guy on ebay keeps asking me what size bulbs do I want? So what do I need to tell him?
Thanks!
Wed Mar 23, 2011 6:44 pm
