It is currently Mon Jul 14, 2025 12:43 pm
Reply to topic  [ 8 posts ]
 Long Tail on a 20 In Transom
Post Long Tail on a 20 In Transom
hey guys, I am going to be buying a boat with a 20 inch transom this spring and want to put a long tail motor on it. Do I have to look for a special mount or long tail? Or can I just buy any of them and mount it up fine? I am working on a very tight budget so I am going to need to find something used and dont want to buy something that will not work.
Sorry for the beginner questions, this will be my first ever boat.
Thu Mar 10, 2011 11:53 am
Post Re: Long Tail on a 20 In Transom
you will probably need a lt with a tall transom mount, they are supposed to run on boats that have a 15-16 inch transom...give coco a call at go-devil and he will tell ya what you need
Running a homemade 14x38 skiff with the good ole' 13 h.p Go-Devil longtail
Fri Mar 11, 2011 2:23 pm
Check out backwaterinc these motors are designed to run on a 19 to 21 inch tanson backwaterinc.com
Sun Mar 13, 2011 8:38 am
I have a 20 inch transom on my boat as well. I just told the boys at MarshMonster that I had a 20 inch transom and they build the shaft of the motor longer and it works excellent. I got a 25hp honda on it. Might want to give those guys a call they know what they are doing!
Mon Mar 21, 2011 9:40 am
Mud Buddy also makes a longer LT for the higher transoms. I think mine is 83inches instead of the standard 73 inches long.
I have never personally used the "tall transom" brackets, but its all about angle. If you put a shorter LT on a tall transom, your motor will be pushing up against the boat in the front and kill performance.
MB 35hp LT/1754 Grizzly
Mon Mar 21, 2011 5:40 pm
Mon Mar 21, 2011 6:01 pm
The Mudauber will work fine on a 20"
Mon Mar 21, 2011 7:09 pm
I bought a GDLT for a short transome. I re worked the cavitation plate and put it on my tall transom boat. It works just fine and drives great! No complaints about it.
Aucoin 18'x48'' Bateau, 30hp GD Longtail.
Mon Mar 21, 2011 7:38 pm
Users browsing this forum: No registered users and 50 guests
