It is currently Mon Jul 14, 2025 9:25 am
Reply to topic  [ 18 posts ]
 11 hp homebuilt LT ??
Post 11 hp homebuilt LT ??
I just recently purchased a Harbor freight 11 hp Honda clone for a smoking deal. I will most likely order the eBay mud motor plans but before I did I was trying to see some other 11hp motors. I have found a lot of home-built LT's with 6.5 but not so many 11 hp's. Whats your opinion on the the 11hp LT compared to the 6.5 or 9 or 13hp's. Also I would like prop recommendations for an 11hp. Thanks
Sun May 08, 2011 3:37 pm
Post Re: 11 hp homebuilt LT ??
i built one with an 11hp tecumseh a while beack and recently bought the 11hp HF motor. LOVE the motor so far. i just got it on the frame tonight. ill be puttin a video up online sometime tonight for ya. according to the manuals everything on the 11 and 13 are the same except for the displacement size. i dont think ya really NEED the plansm i fiugure everything out after LOTS and LOTS of research.
Save your confederate money, cause the south WILL rise again
homebuilt 11 HP greyhound LongTail
-1436 flatbottom
Sun May 08, 2011 3:52 pm
Thanks I would love to see what you have. I haven't bit the bullet on the plans yet I think I will probably do it without them. What size prop are you running?
Sun May 08, 2011 4:02 pm
8x4 prop
Sun May 08, 2011 8:47 pm
holpefully the video will work, it was done with a phone and for some reason my phone doesnt pick up sound though..
im runnin an 8x4 and the only major problem i got left now is that my seals are just sittin inside the shaft, the bottom one stays in by the prop and the top one held in by a ziptie. i need to put caps on each end of the shaft to keep the seals in place. and i sont have a bearing at the top, wish i would have done that, but i dont think its absolutely necessary now, but u defionitely need to have one since u starting fresh.
the fuel bowl nut drips gas when the engine is off, havent looked much into it and not sure if it does it runnin or not, thats the only problem ive had so far. it started in the first pull straight out of the box. no priming, nothing.
-1436 flatbottom
Sun May 08, 2011 9:27 pm
i just bought that same motor about two weeks ago. i am going to put it on my go-devil longtail frame after i get the seals replaced. hoping for good results. the whole setup is going on a 1436 jon boat.
Nick "Ichabod"
Waterfowl Mafia
Hampton, FL
Mon May 09, 2011 2:35 pm
Fishon where did you get your universal joint from
14 by 44 Weld Craft powered by a 20hp. go devil longtail
Team Arc Angel Bowfishing
Mon May 09, 2011 3:18 pm
i think i got the whole thing from tractor supply. all the bushings and seals cam e from mcmaster.com which is a GREAT place to check out. they pricey but have things that can be hard to find. i also found later that home depot has some brinze bushings.
-1436 flatbottom
Mon May 09, 2011 5:32 pm
yall dont have any problems with the low oil shut off? Looking at getting that 11hp one from harbor freight.
27 Contender twin 200's
for sale
Thu May 19, 2011 10:29 am
dunno, havent ran it on low oil yet
-1436 flatbottom
Thu May 19, 2011 5:09 pm
jus kiddin.
i havent run it that much yet, i think i remember reading something about the engine not starting when it has plenty of oil. they bypassed the shutoff and it started right away. if it ever happens ill just bypass it too, you should ALWAYS be keepin an eye on oil anyway
-1436 flatbottom
Thu May 19, 2011 5:10 pm
Have you guys tried out that 11 hp honda clone (greyhound) on your home built. Does the engine do ok? Let me know because I might start building some. I checked and Harbor Freight only listed a 6.5 hp Greyhound.
Its a lazy man that can't find his wife a second job!
Fri May 20, 2011 2:17 am
uuuuhhh..... thats the motor we been talkin bout...
-1436 flatbottom
Fri May 20, 2011 3:06 pm
Fri May 20, 2011 4:41 pm
I know that is the motor your talking about. No one with it has said what the preformance has been on the mud frame! Dah!
Sun May 22, 2011 12:36 pm
Me and a buddy made one last year and it's awesome! Love it. Where you going to put the throttle on that u handle you have? I see you got that idea from scavenger mud motors
Sat Jun 18, 2011 10:29 am
I'm looking at building a frame for a couple motors that I can use, anywhere from 6 - 9 hp. Does anyone have some plans or ideas on how to get the frame set up as well as the shaft to motor setup. I'm running an outboard right now and am tired of getting tangled up in hydrilla everytime i run it.
Thu Jun 23, 2011 3:27 pm
Thu Jun 23, 2011 5:05 pm
Users browsing this forum: No registered users and 35 guests
