It is currently Tue Jul 15, 2025 7:00 pm
Reply to topic  [ 17 posts ]
 trailering a longtail.
Post trailering a longtail.
im tryin to figure a way to strap down my motor without using a strap across the handle anymore. im tryin to come up with an idea of a way to put a lock of some sort on the part where it attaches to the transom. anybody done anything like this before.
Sun May 29, 2011 12:10 pm
Post Re: trailering a longtail.
i'm workin on the same problem right now.. i think i'm probably gonna try to make a swivel bracket to reverse the motor. but i'll let you know if i figure something out
Sun May 29, 2011 2:47 pm
I had the same problem, made a transom saver to keep the shaft from flexin and bouncin on these wonderful Louisiana roads :roll:
I put a small peice of channel on the boat trailer with a hole drilled through both sides, found a peice of thick wall pipe and drilled matching holes in it, then took the grinder and ground a slit into the pipe on the other end drilled holes through it and the skeg, I keep all of it on with d-pins and can take it off quick at the launch.
Sun May 29, 2011 4:31 pm
One mo.
Y'all are something else. Don't be afraid to tie off on the handle. That motor is balanced and there is nothing to worry about. I have a piece of rope that loops over the handle to keep the prop out the water if I need to do something in the boat while the motors running. sometimes I trailer with just that and the motor just floats there it doesn't bounce around like you think. Tying off on the handle will not cause any problems, trust me.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Sun May 29, 2011 5:12 pm
Swivel bracket here and built one of these I use rivets though
http://www.mudbuddy.com/Store%20specifi ... 0Spec.html
Sun May 29, 2011 6:00 pm
i mounted a kolpin rhino grip gun holder in the middle if my back bench on my boat. when u load up just set the handle in there and strap it and go. works perfect.
Tue May 31, 2011 1:46 am
made the same out of scrap i had laying around, but here is the twist. Put a suction cup on the bottom as i dont want to put this where i will be standing.
Wed Jun 01, 2011 10:22 am
Use a piece of rope accross the gunnels and around the handle like GoDevil does.This puts no strain on the handle and does not jar the motor and frame like bolting it down.No offense but to the fella using a suction cup-do you really want to depend on a suction cup when trailering before daylight?
Sun Jun 05, 2011 7:44 pm
Don't Tread on Me
Sun Jun 05, 2011 9:09 pm
From the Go-Devil owners manual:
Sun Jun 05, 2011 9:18 pm
That is a good idea woodie i think im going to do that with mine. I hate havin to unratchot that thing in 20deg. weather with gloves on.
14 by 44 Weld Craft powered by a 20hp. go devil longtail
Team Arc Angel Bowfishing
Sun Jun 05, 2011 9:21 pm
What schedule pipe did you use? Wondering if a piece of galvanized hurricane fence pipe wold hold up?
Tue Jun 07, 2011 5:31 pm
Shoot i dunno how thick it is, I just drug it up one day.
The walls are about 1/4 thick and thats more than enough.
Tue Jun 07, 2011 5:38 pm
You get more wear and tear on the transom with an outboard than with a longtail.
I tie mine off by the handle just like the manf. showed and it works fine. Most of the weight is inside the hull anyway.
S
1854 Prodigy Open
HDR/Stage 3 mods
Prodigy Boats Pro Staff
BPS Swamp Staff Member
Blackwater Marine LLC.
Mon Jun 20, 2011 11:25 am
It's not the weight that tears up the transom, it is the motor bouncing unsecured. You are correct about the outboard. But the longtail is balanced that's why it doesnt slap around.
Mon Jun 20, 2011 12:13 pm
Just completed the "Woodie Buster" special. Used a piece of 1 1/4 conduit for practice(may even work), got a piece of aluminum pipe on the way.
Mon Jun 20, 2011 3:32 pm
Users browsing this forum: No registered users and 55 guests
