It is currently Sun Jul 13, 2025 11:05 pm
Reply to topic  [ 5 posts ]
 cavitation plate setup
Post cavitation plate setup
So we are down to the nitty gritty of design ideas before we begin the build and have come to the cavitation plate...
The guy who built the motor said the hardest part he had was adjusting the cavitation plate, he said he had to weld it up go run the thing then go home, cut it off and weld it back on at a different angle. (see red cav plate in picture) He has access to a welder at his house and im not so fortunate. :( Anyways, I was wondering if I could weld on the actual plate it self at a set angle (such as level or so) to the shaft housing and then take a piece of strap or angle and bolt it to the end of the plate and bend it for the push needed to keep the prop in the water? (see green/blue cav plate in picture) Would this setup work? I realize i will have to play with the angle of the cavitation plate, but If i could bend the end while the plate stays the same vs cutting and re-welding that would be amazing! 8-)
Thanks for the help, and sorry for the 2 minute paint sketch-up!
1436 Lowe
Sun Jun 19, 2011 10:11 pm
Post Re: cavitation plate setup
when i built mine last week i just made it so the end of the cavitation plate sat 1/2" above my prop, and bent the trailing edge down on a slight angle. took her out for the first test run and it works amazing. the plate makes the prop sit just under the water.
Sun Jun 19, 2011 10:19 pm
I have the same plans as solo, they say 1/2" above prop.I went 1" above just in case I want to run a bigger prop. I ran my cav. plate straight so I could bolt on a bendable piece like the second diagram. In the instructions it says to bend the last inch of the plate down, but to me that would make you slower as well as loose torque. In effect acting like a parachutte.
Mon Jun 20, 2011 5:57 am
Can't you use a nut and bolt setup of some sort to get the angle, and then weld once you have the correct pitch?
(can't see the pics, work filter)
If you pick up a starving dog and make him prosperous,
he will not bite you;
that is the principal difference between a dog and a man.
-Mark Twain
Mon Jun 20, 2011 1:31 pm
Sure , I don't see why not. But if you are going to wind up weldin it anyhow just do it so your not wasting time drilling holes?
Mon Jun 20, 2011 9:42 pm
Users browsing this forum: No registered users and 45 guests
