It is currently Tue Jul 29, 2025 11:09 pm
Reply to topic  [ 15 posts ]
 Hydro-Turf
Post Hydro-Turf
When installing Hydro Turf with the 3M backing is it strong enough to hold up. Do I need to put any other adhesive down. (I searched the forum and could not find anything on this.)
Tue Jun 21, 2011 11:49 am
Post Re: Hydro-Turf
no, i used the 3m and it is incredibly strong. i had to remove a square of it later to install a seat base and i actually had to chip it off.
Tue Jun 21, 2011 12:04 pm
MMT Moderator
Post Re: Hydro-Turf
x2 tough stuff!
GTB 1860 w/ 2019 GTR40XD-HO
Tue Jun 21, 2011 1:35 pm
Post Re: Hydro-Turf
U can u the 3m spray adhesive to help keep the edges down
I work for money. If u want loyalty, go buy a dog.
Sun Jun 26, 2011 6:15 pm
Post Re: Hydro-Turf
The 3m backing is all you will need, once it's down it ain't coming back up.
Sun Jun 26, 2011 8:17 pm
Post Re: Hydro-Turf
Where do you get the 3m spray adhesive
Tue Jul 05, 2011 12:54 pm
Post Re: Hydro-Turf
3m spray adhesive can be bought at lowe's/home depot/walmart etc... (although I seem to recall that one of them only carries a proprietary brand now)..
But he is talking about a 3M backing that comes on hydro turf as an option. You can buy it with or without the 3m adhesive backing (better than the spray can ).
Best two options are get the 3m backing that comes on it (they charge you extra for it) or use contact cement.
3m spray adhesive will work but probably not your best option.
Tue Jul 05, 2011 1:05 pm
Post Re: Hydro-Turf
Look into a product called Seadek also. http://www.seadek.com/ I have seen this on flats boats in s fl and got the samples, pretty nice stuff.
Just a displaced hillbilly in Cajunland
Beavertail Predator LT/17' alum vee total mismatch but ya use what ya gots
Tue Jul 05, 2011 9:17 pm
Post Re: Hydro-Turf
liquid nails makes a product in a brush or roll on that works very well. i used it on the carpet in my boat. its alot stronger than contact cement. as for the 3m spray they have 2 types. one is the regular the other is stronger gray can if i remember. it is better. i would clean the surface very well before i used the the 3m or contact cement. in the past they dont seem to grab as well as i would have liked. now the liquid nails stuff is very strong its a little thicker than contact cement. also around the edge i used regular liquid nails to keep it from rolling up. it grabbed almost instantly. in the past thats where ive found the problem, the field never seems to let go but the edges will.
Wed Jul 06, 2011 7:08 am
Post Re: Hydro-Turf
Would a person have to sand up the non skid paint first to get it to stick?
18x54 WC custom
36PD EFI
Wed Jul 06, 2011 7:47 am
Post Re: Hydro-Turf
it would help. at least it would even out the surface so everything would stick with no high and low spots.
Wed Jul 06, 2011 8:08 am
Post Re: Hydro-Turf
ok cool just wondering
18x54 WC custom
36PD EFI
Wed Jul 06, 2011 9:41 am
Post Re: Hydro-Turf
will the hydro-turf adhere with spray adhesive. i want to install the stuff, but have the spray-in liner.
Fri Jul 08, 2011 6:20 pm
Post Re: Hydro-Turf
sandpaper to get the nonskid off? or angle buffer? any suggs.?
Boone Barton Western KY
2015 Havoc 1650 MST .125
2015 35hp Hyper
Stock for now, goodies soon to follow.
Sat Jul 09, 2011 7:46 am
Post Re: Hydro-Turf
try a wire wheel or a 80 grit flapper wheel on a 4" grinder... will scuff it up good
I gave up mud motors
Sat Jul 09, 2011 7:51 am
Users browsing this forum: No registered users and 127 guests
