It is currently Wed Jun 25, 2025 3:13 pm
Reply to topic  [ 25 posts ]
 Not the right equipment for this situation
Post Not the right equipment for this situation
Wed Aug 31, 2011 10:09 am
MMT Moderator
Post Re: Not the right equipment for this situation
That truck needs about 4" more lift & 38's under it... Lockers F&R would have helped. Whose winching that?
GTB 1860 w/ 2019 GTR40XD-HO
Wed Aug 31, 2011 10:15 am
no winching, had a friend pull me oout. yea i wish i could put a bigger lift/tires on it. don't need lockers all 4 pull for now. wanting to put a small block in it first
Wed Aug 31, 2011 10:24 am
MMT Moderator
Wed Aug 31, 2011 10:28 am
Not on this lil chit, when in 4x4 it's 4x4. don't ask why it just is. never seen it 3wd
Wed Aug 31, 2011 11:33 am
Flex it in a ditch I bet the first wheel to come off the ground will spin and the one touching will not. Lockers pull ALL THE TIME.
Ill play... Toyota on 38's
Wed Aug 31, 2011 12:15 pm
MMT Moderator
22RE? or did you get the 3.0L?
Wed Aug 31, 2011 12:18 pm
3.slow =( its on the way out. Used to be able to turn the 38's well with the 5.29 gears, But since I added the Dual transfer cases the parasitic loss and 213k miles is catching up with it. It lacks the Horsepower.
Wed Aug 31, 2011 12:19 pm
Wed Aug 31, 2011 12:48 pm
MMT Moderator
305/327 or 350 all are fairly straight forward swaps. Is your pumpkin on the front axle a passenger side drop? Atlas T.C.?
Small Block for sure your are limited in space with most Toys
Wed Aug 31, 2011 12:50 pm
I've passed in some ditches and never had it free wheel. thought I was fuked, ditch was a lil soft. don't lnow what it is about my lil black, just wish I could afford to do more to it (performance) wise that is. fuking lift kits are expensive, was looking for a front straight axle conversion kit.
Wed Aug 31, 2011 1:01 pm
MMT Moderator
You may have a positrac or limited slip in that diff.
Wed Aug 31, 2011 1:10 pm
I've been working at a chevy dealer for almost 22 yrs, I know a lil about it. when I replaced the gears the front was open (no locker) the rear has a posi unit. I have pulled on several things, got stuck twice. Second time is the picture (tires where bald) hit a big hole past my knees & centered the truck, towing a boat did not help either. but anyways which it had more that the 4.3 V6 it has now. but that's another story, wanting a mm rig now with no $$$$$$$
Wed Aug 31, 2011 1:32 pm
MMT Moderator
I would have saved a sh!t load of money by purchasing a MM rig back in the day rather than trying to mud my Toy. Let's see...
4" Lift, 33" Tires, Detroit Locker, custom front bumper, winch mounts, 4.88 gears, crawl kit, extended travel kit, removed sway bar since it was no longer a grocery getter... commenced to blow the engine, twice! Rebuilt it and bored it over .040 or is it .004 forget which lol...
Anyways it was a beast. Bought it for $10K sold it for $12500
Wed Aug 31, 2011 1:44 pm
When I get the want to mechanic on it again it will put some sort of GM LS engine, 4l60e or 4l80e trans, and a Np241 passenger side with VSS. I have a passenger drop axle, But once i upgrade to aV8 I will get away with toyota axles for a while, then I will want 1 Ton axles!
Wed Aug 31, 2011 1:48 pm
Now that's what I'm talking about & from what I have read in here sooping up a MM is not dat CHEAP either
Wed Aug 31, 2011 2:02 pm
Wed Aug 31, 2011 2:09 pm
^^ I had 6.0. I bored 30 over put H beam rods valve release pistons heads cam rockers intake long tube headers 175 nitrous and a dyno tune all in a extended cab 02 chevy 1500 and it blew more 4l60e than I knew what to do with
Wed Aug 31, 2011 4:50 pm
Wed Aug 31, 2011 8:20 pm
Post Re: Re: Not the right equipment for this situation
Wed Aug 31, 2011 8:32 pm
I tell you what you sure are quick to call someone out but when its you you get all butt hurt and cry like a lil bit*h, go play with your toys and little the grown ups talk.....Now i see why you have the word DICK in your name you little cock sucker
Wed Aug 31, 2011 8:35 pm
I wanna play
I gave up mud motors
Wed Aug 31, 2011 8:38 pm
Wed Aug 31, 2011 8:40 pm
your too easy.
Wed Aug 31, 2011 9:04 pm
Users browsing this forum: No registered users and 26 guests
