It is currently Wed Jul 09, 2025 1:19 pm
Reply to topic  [ 6 posts ]
 Homemade Longtail
Post Homemade Longtail
I am making a LT and have everything ready to go beside the lower bearing housing. I have two ideas of doing it.
1. I bought a pipe fitting thats 1 by 1 1/2 reducing, I would than weld the 1" side to the shaft housing and insert bearing in 1 1/2" side put a couple seals in and than a cap with a 3/4" hole.
2. Just find a pipe with a ID of 1 3/4" so the bearing snug, weld it onto the shaft housing, the other end machine threads in and have a couple seals and a cap with a 3/4" hole.
What do you all think would be better?
Any other ideas?
Thanks
Thu Jul 21, 2011 4:10 pm
Post Re: Homemade Longtail
Bronze bushings and seals. You would be amazed the variety of sizes they make.
Thu Jul 21, 2011 10:39 pm
x2, beside much easier to assemble.
Fri Jul 22, 2011 9:27 am
you need a bearing housing at the top, seal housing at the bottom. nothing big for your seal housing just something to keep em in place.
Save your confederate money, cause the south WILL rise again
homebuilt 11 HP greyhound LongTail
-1436 flatbottom
Fri Jul 22, 2011 8:54 pm
bronze bushing and locking collars tractor supply sell them
Fri Sep 09, 2011 12:51 am
I found a bearing housings that would fit a tapered roller bearing that I have a shaft collar and than two seals than my cap
Sun Sep 11, 2011 7:35 pm
Users browsing this forum: No registered users and 39 guests
