It is currently Sun Jul 13, 2025 9:46 am
Reply to topic  [ 42 posts ]  Go to page 1, 2  Next
 New belt & prop @ 100 hours
Post New belt & prop @ 100 hours
Ordered a new belt and prop from Gator-Tail this AM.
Those guys are very nice and prompt to return calls and emails
So here's what's been happening.
Heard a grinding noise at take off and it progressed to a noise like ice in a blender.
Checked belt and it is super loose. Measured deflection and it's 3/4" on both sides. It's supposes to be 1/4".
GT said it's time for new belt! Hopefully gears are ok from the slipping.
Also been noticing a ton of vibration. Backed out muffler support bolts.
Checked prop length and it's 10" instead of 12"
Called gator tail- time for new prop!
Excited to get new parts on- wife however is not so excited about having to buy parts lol
Replacing belt sounds easy, we shall see
Tue Nov 15, 2011 8:54 am
Post Re: New belt & prop @ 100 hours
:? Wait, you had to buy a belt? Or just a prop?
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Nov 15, 2011 11:06 am
Eat - Sleep - Hunt ! ! !
Tue Nov 15, 2011 12:40 pm
MMT Moderator
GTB 1860 w/ 2019 GTR40XD-HO
Tue Nov 15, 2011 12:46 pm
Had to replace both full cost
$120 for belt
$250 ( I think) for prop
Tue Nov 15, 2011 1:06 pm
MMT Moderator
Price sounds right. I need to call & order another prop. Have they restocked yet?
Tue Nov 15, 2011 1:09 pm
Said they should have them today
Tue Nov 15, 2011 2:14 pm
Tue Nov 15, 2011 2:15 pm
MMT Moderator
Tue Nov 15, 2011 2:20 pm
2010 didn't come wif a lifetime belt warranty? That was just last year. R is the belt warranty not transferrable?
18'x54"CC Hanko/ 36PD
Tue Nov 15, 2011 3:10 pm
MMT Moderator
Tue Nov 15, 2011 3:13 pm
Think they said march 2010- this motor was purchased in late 2009 though-
Tue Nov 15, 2011 3:46 pm
All engines purchased on 3-1-10 and after come with a lifetime belt warranty.
Tue Nov 15, 2011 3:52 pm
Does the new belt he purchased come with a lifetime warranty? Or is it a different belt-
Put yer face in the myrtles.
Tue Nov 15, 2011 5:47 pm
Tue Nov 15, 2011 7:03 pm
Craig, thanks for the clarification. I was also under the impression it was all 2010 year models. Now, is the warranty transferrable if the motor is sold? It really has no effect on me personally, but I'm sure there's someone that it would effect.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Nov 15, 2011 7:09 pm
Tue Nov 15, 2011 8:36 pm
That's a big negative, brotha. At least not as far as I know anyhow.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Nov 15, 2011 8:56 pm
make sure you get a piece of plastin banding material. wrap it around the belt at the bottom leave it hang out the belt housing that way you have something to pull the belt over the gear. will save you alot of headache
Tue Nov 15, 2011 9:05 pm
Wed Nov 16, 2011 6:09 am
Took apart the lower unit and sent pictures off to gator tail- got a call within 10 minutes
Turns out the lower pulley's teeth are
worn and they had already boxed up a new one to send me today, compliments of GT.
Very happy with the customer support at Gator-Tail
Wed Nov 16, 2011 11:51 am
MMT Moderator
That's good service right there!!
Wed Nov 16, 2011 12:00 pm
^^^x2
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed Nov 16, 2011 1:55 pm
with this kind of service its going to make me pull the trigger and order mysellf a GT!
1436 custom walked slowly by a 13hp Homemade LT.
The second amendment is what makes the first amendment possible.
Wed Nov 16, 2011 2:07 pm
Allways pays off when the customer is first in the sellers eyes. Myself have never had a problem, always gotten the parts the week i made the phone call, haven't missed a hunting weekend yet. Good job for the GT boys/girls
Wed Nov 16, 2011 2:12 pm
Wed Nov 16, 2011 3:20 pm
Wed Nov 16, 2011 3:23 pm
got new bottom gear today- went ahead and installed it-
Having trouble aligning the belt. Seems to want to fall off the top gear. Going to try to move the shims around tomorrow and see how that works
Fri Nov 18, 2011 10:31 pm
Anyone have an idea why the belt would want to come off top gear?
Maybe too tight?
Sat Nov 19, 2011 5:15 pm
Shimmed too high in front, too low in rear, causing belt to walk off?
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sat Nov 19, 2011 8:14 pm
shimmed it up on the back side- the belt wants to hang off about 25%
Need to call gator-tail and see if this is correct
Sun Nov 20, 2011 4:38 pm
Sun Nov 20, 2011 4:40 pm
Here are the shots
Sun Nov 20, 2011 6:05 pm
Definitely NOT right!!!! Makes me wonder if the pulleys are inline correctly.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Nov 20, 2011 7:38 pm
Back of the motor needs to be shimmed a little bit to make the belt ride alittle more on the pulley, just had this same problem
Sun Nov 20, 2011 7:40 pm
I took a single set of shims from the stern side and placed
A set of shims and a set of washer on the bow side- should I have added shims to the stern side of
the motor?
Sun Nov 20, 2011 8:02 pm
If you shim the front (bow) of the motor more than the rear (stern), then the belt is going to walk off because it would be pulling in that direction. Think of it like a bowl of water, if you tilt it up too much on one side, the water will run out of the other side.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Nov 20, 2011 8:12 pm
Both the back bolts need to be shimmed equally, if not motor will sit cock-eyed
Sun Nov 20, 2011 8:13 pm
Sun Nov 20, 2011 8:14 pm
Post Re: lt & prop @ 100 hours
do a little at a time just a little will make the belt move a good bit
Sun Nov 20, 2011 8:16 pm
Users browsing this forum: No registered users and 28 guests
