It is currently Tue Jul 08, 2025 8:43 pm
Reply to topic  [ 3 posts ]
 longtail shaft housing build??
Post longtail shaft housing build??
hey everyone. im new here ive read just about every post on longtail home builds. i have started my build but im stuck on building the housing for the shaft . if someone could please chime in and guide me in the direction i would greatly appreciate it. thanks
Fri Jan 27, 2012 7:42 pm
Post Re: longtail shaft housing build??
figure your bearing housing situation first. i built an old school using 1'' schedual 40 pipe. i made my end caps with pipe couplers bored to accept oil seals and bought 1 1/16'' bronze bushings and had them turned down to pipe id leaving a flange "gd rip off" . My friend made his with DOM tubing and bearing in a housing that presses on. plumbing supplies are easier to come by for me.
Sat Jan 28, 2012 7:36 am
I'm currently building two long tails. I have ordered parts from mcmaster carr and grainger. I am making the shaft out of 3/4 steel shafts. The bronze sleeve bearings are 3/4 i.d. x 1 1/4 o.d. My outer tube is 1.5 dom tubing with .120 wall and the i.d. is around 1.260 leaving.010 slop but im using loctite 620 retaining compound to fill the gap. It has 400o p.s.i. shear strength and double lip seals.As soon as i'm finished i can send part numbers and drawings.
Tue Feb 07, 2012 12:42 pm
Users browsing this forum: Google [Bot] and 59 guests
