It is currently Tue Jul 08, 2025 7:14 am
Reply to topic  [ 7 posts ]
 Changing seals and bushings on a gdlt
Post Changing seals and bushings on a gdlt
I'm wondering how hard it is to change out the seals and bushings on a gdlt. Hoping somebody might have put together some pictures or a how-to thread.
Sun Feb 05, 2012 9:03 pm
Go to the GoDevil website and view the owners manual.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Sun Feb 05, 2012 9:04 pm
So it's a really simple job-
Remove the shaft - change the seals no problem
The bushing are a bit tricky - you need to pop them out - I used a puller - simple take out and replace
I suggest removing the current grease and refilling it - you don't have to - but it's a good idea
Put everything back where it needs to be - insert shaft keyside first - do not send the threads through your new seals - grease it up - attach the yoke - go play!
Really simple to do
I've done it a few times - let me know if you run into any snags
B.
B. MacDonald
Mon Feb 06, 2012 7:29 am
Use a hacksaw blade and make about four or five cuts through the bushing. No need and much easier that a puller.
Mon Feb 06, 2012 7:34 am
Post Re: Changing seals and bushings on a gdlt
B. MacDonald
Mon Feb 06, 2012 1:27 pm
Why would one take a bushing out and reuse it later? If it's worn to shit it will still be worn to shit when you put it back in. If it's still good leave it in, no need to pull it out for a seal job.
Mon Feb 06, 2012 6:02 pm
I pulled it out to replicate it - made a few of my own
No more $25 bushings +shipping from GD for this guy :)
B. MacDonald
Mon Feb 06, 2012 8:33 pm
Users browsing this forum: No registered users and 44 guests
