It is currently Sun Jul 13, 2025 4:00 am
Reply to topic  [ 22 posts ]
 Stripped threads
Post Stripped threads
When I took the nut off to get my prop off the threads was stripped . It took me a while to get the nut off, I had to tighting and loosening alot , I thought it was the pastic from the nut making it hard . What do they do about this?? It's a 35gtr Thanks.
Mon Feb 06, 2012 9:09 pm
Post Re: Stripped threads
You can try to chase it with a die and see if that works. If there ain't enough material there I would imagine you need to replace it.
Mon Feb 06, 2012 9:12 pm
^^^^^yep.....I would be safe and just replace it, save you a lot of headache in the long run
Mon Feb 06, 2012 11:06 pm
MMT Moderator
You should be using a brass nut if running saltwater
GTB 1860 w/ 2019 GTR40XD-HO
Mon Feb 06, 2012 11:09 pm
Kool-Aid Brigade
www.southernfowler.com
Tue Feb 07, 2012 7:54 am
Stainless nuts are good, But if you have a stainless shaft, you need to be aware of the proper lubricant required to use stainles on stainless... Or you will have corrosion issues.
Tue Feb 07, 2012 7:56 am
Kool-Aid Brigade
Tue Feb 07, 2012 8:00 am
I am running a stainless nut 3CK, put some neva cease and roll with it
Tue Feb 07, 2012 10:56 am
Robin2 on here works in the plants where they use stainless on stainless fasteners. He suggested Milk of Magnesia to lube the threads!
Tue Feb 07, 2012 11:18 am
yeah I just changed my prop this weekend. Put a new SS nut on it as provided by GT. The old one came off without much problem even after 83 hours of solid salt water use.
Now the prop itself was a little worse for wear. haha.
Kool-Aid Brigade
Tue Feb 07, 2012 11:40 am
Thanks for all the replys , I guess I will have to get a new shaft , does anyone know the price gt charges for one ?
Tue Feb 07, 2012 4:16 pm
MMT Moderator
Depending upon where the threads are stripped... You may be able to cut the grooves back in it.
I found this issue after removing my prop the night before installing a new one. I put the nut back on hand tightened then gave it a few turns with the wrench to tighten it up. 12 hours later it was seized on there & wouldn't budge! After some heat & cooling we were able to get the prop off it scarred the threads bad chased it and was able to run all weekend. Later changed out the output shaft to a 32"
I'll take a macro picture later once I get back to the house.
Tue Feb 07, 2012 4:29 pm
Are you sure it's the tread and not the nut!! Had some nuts that was really hard to get off but nothing was wrong with shaft
17x48 extreme stage 2 GTR
Tue Feb 07, 2012 4:39 pm
Snap a pic on the shaft and the inside of the nut.
Tue Feb 07, 2012 4:42 pm
MMT Moderator
Here's what my shaft looks like. We chased it and the nut does go on & off. However you can see we damaged some threads trying to remove the nut. The threads were damaged near the end of the shaft. We were using power tools and heat after we knew we screwed it up & needed to get it off to fix. I was able to chase the threads and remove the nut that disintegrated around the shaft. Ever since then been running a brass nut that Baumann Marine gave me.
I am now running a 32" shaft & the stock shaft is in the garage.
Tue Feb 07, 2012 4:57 pm
I think he was talking about the guy with the problem!!
Tue Feb 07, 2012 5:21 pm
MMT Moderator
Tue Feb 07, 2012 5:29 pm
How do you post pics from a iPhone
Tue Feb 07, 2012 6:30 pm
MMT Moderator
Tue Feb 07, 2012 6:46 pm
use a rethreading die not a cutting die. same thing on a tap use a rethreading tap not a cutting tap. there is a diff.
Sun Feb 12, 2012 8:34 am
18x54 WC custom
36PD EFI
Sun Feb 12, 2012 10:43 am
Could you take it to a machine shop and have it rethreaded?
1542 War Eagle with 25hp GDLT
Sun Feb 12, 2012 2:15 pm
Users browsing this forum: No registered users and 23 guests
