MallardMan5
 Enough Power?
[list=]Looking at getting a longtail for my 1542 flatbottom. Wondering what is a good size to make sure I'd get thru some shallow water at a pretty good speed. I usually hunt 2 people with gear and about 3 dozen dekes. Let me know what you guys know. Thanks.[/list]
_________________ 1542 Jon/23 Copperhead
Wed Apr 04, 2012 7:11 pm |
Buzz Killington
 Enough Power?
Can't go wrong with a 23hp. Although I see everyone telling you to get a 35. I use a 20hp and it moves a similar load quite well.
B. MacDonald
Wed Apr 04, 2012 7:15 pm |
med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
 Re: Enough Power?
Get the biggest that you can afford and that your boat can handle. I've had a 23lt, 25lt, 31sd and a 27sd and never thought to myself "I have plenty of power and I'm satisfied".
_________________ 1850 & 36pd
Wed Apr 04, 2012 7:22 pm |
PaleoHuntr
Joined: Mon Feb 21, 2011 5:21 pm Posts: 1800 Location: Idaho Falls, ID
 Re: Enough Power?
define "pretty good speed". How much does the people and gear weigh?
_________________ 1976 16X48 Lowe powered by a 25hp MB LT and dino turds
Wed Apr 04, 2012 7:28 pm |
Woodiebuster
 Re: Enough Power?
It should float a 35 lt if there isnt alot of wieght in the back.
Wed Apr 04, 2012 8:19 pm |
SwampDonkey1
Joined: Tue Mar 08, 2011 10:09 pm Posts: 923 Location: North Central KS
 Re: Enough Power?
Bigger is usually better!
_________________ 1436 Lowe -Workin for the man, Huntin when I can...-
Wed Apr 04, 2012 10:05 pm |
bignate176
Joined: Mon Oct 10, 2011 5:10 pm Posts: 96 Location: Ridgeville, SC and Harrisburg,IL
 Re: Enough Power?
I'm runnen a 31 GDLT on a 1548. runs pretty good even with 3 people and gear. would run a hole lot better if i didn't have a worn prop. if you can put gas tank and battery in front and be able to float a 35, i would go with a 35. don't get me wrong i love my 31 but i personally wouldn't mind getting my hands on a 35. With worn prop, 3 guys, and ton of gear im getten 10. just me and gear (3-5 dozen deeks) im getten 15.
_________________ “I can only say that I am nothing but a poor sinner, trusting in Christ alone for salvation.” ― Robert E. Lee
Wed Apr 04, 2012 11:51 pm |
PaleoHuntr
 Re: Enough Power?
What conditions are you running that you want a longtail? If your buying new I would consider on of the mini SD's, unless you need a longtail.
Wed Apr 04, 2012 11:56 pm |
MallardMan5
 Re: Enough Power?
I want to get around 10 to 15mph. Most of what I hunt is 2 to 3 foot of water but there are places with only a few inches of water that I would love to get my boat back into. The reason I'm looking at a longtail rather than a surface drive is to save some money. I'm only looking to spend $1000 to $1500 on a used motor. Any thoughts? Thanks fort you input so far.
Thu Apr 05, 2012 5:41 am |
PaleoHuntr
 Re: Enough Power?
Well in that case, look around and buy the biggest you can afford. But anything from a 23 and up will work for you.
Thu Apr 05, 2012 8:04 am |
Glades Ranger
Joined: Mon Sep 19, 2011 6:32 pm Posts: 1490 Location: south Florida
 Re: Enough Power?
I concur to go for the 23 HP on that 1542. I think the price, output, available mods in the future if you want to go that route, weight, reliable record, availability of Briggs parts and service centers, all make that motor a good choice. There are times when I wish I had a longer run, deeper water, bigger water, to go duck hunting and needed a surface drive....NOT! I like the fact I don't have to race, I am in a sheltered marsh primarily, skinny water, hard bottom, and the longtail shines!! I don't have to feel inferior and drool everytime Billy Boo drives by at 34 mph in the latest modded shortail mudder with the perfect camo, and mega watt stereo blaring.....well, ok, two more mph would be great.
_________________ Sailing in the sawgrass /1648 grizzly and Swomp 26.5 EFI
Thu Apr 05, 2012 10:58 am |
