It is currently Mon Jul 07, 2025 5:45 am
Reply to topic  [ 8 posts ]
 boat wants to pull to the right.. I this normal?
Post boat wants to pull to the right.. I this normal?
My boat wants to pull to the right while running an I have to constantly pull the handle towards me.. Is this normal or can something be adjusted to cure this problem?
Mon May 07, 2012 5:48 am
Post Re: boat wants to pull to the right.. I this normal?
What motor? It should have a tab on the skeg u can bend to offset the prop.
Mon May 07, 2012 6:38 am
Could be a few things. As robin said check your skeg, but it could be something as minor as adjusting the weight in your boat or your motor could be sitting too far to one side of your transom.
1542 War Eagle with 25hp GDLT
Mon May 07, 2012 6:55 am
I'm running a scanengrr backwater 25 hp on a 14ft v bottom. And I've tried moving the weight around and the motor is in the middle.. But it also runs to the right real bad when I get it in the mud.. So I don't know what to do. This is the first mud motor I've owned so I don't know much about them and how they act
Mon May 07, 2012 7:08 am
longtail or surface drive?
if surface drive, you need to bend the offset tab on the skeg or trim your motor up higher while running.
if longtail, assuming correct mount position, you need to shift weight left and right until there is no tiller torque whatsoever. one person sitting all the way to one side will wear you out fighting the handle.
Mon May 07, 2012 6:22 pm
If the boat has alot of v, that can be the problem.
Mon May 07, 2012 6:39 pm
It's a lt and its a semi v not a lot of "v" in the water tho I have tried to move things around and shift weight but it don't help.. I'll keep messing with it I guess.. Thanks for the help guys!!
Mon May 07, 2012 7:40 pm
Tue May 08, 2012 3:18 pm
Users browsing this forum: No registered users and 63 guests
