It is currently Sun Jul 06, 2025 1:10 am
Reply to topic  [ 11 posts ]
 BENT SHAFT AGAIN
Post BENT SHAFT AGAIN
Started with cold roll steel, bent it, made one out stainless bent it today. Have 22 hp engine with 3/4 shaft and bearings top and bottom. Have brass washer in front of prop and nylon behind prop. Was running half throttle when I hit log. Any suggestions thanks
Sat Sep 15, 2012 6:20 pm
Post Re: BENT SHAFT AGAIN
Pics needed. Sounds like you need to either beef up the structure or add support to the shaft.
Sat Sep 15, 2012 6:46 pm
The outer shaft is 1/4 inch steel tubing. I keep bending the 3/4 inch prop shaft.
Sat Sep 15, 2012 7:06 pm
Picture of motor.
Sat Sep 15, 2012 7:16 pm
So it is bending at the prop?
gtr35 gt 1854 / w gatorglide
12 ft 11hp longtail
14 ft 10 hp longtail
Merc 225hp TR20
Sat Sep 15, 2012 7:25 pm
where is it bending? shorten the gap between yur prop and shaft housing.
Sat Sep 15, 2012 7:27 pm
I have a 3/4 inch nut, a 1/16 inch brass washer and a 1/16 inch trush washer between prop and bearing housing.
Sat Sep 15, 2012 7:32 pm
Sat Sep 15, 2012 7:46 pm
what size and motor have you got?
Sat Sep 15, 2012 7:55 pm
35
Sat Sep 15, 2012 8:13 pm
Stop hitting logs?
Put 1 nut and 1 washer above the prop to the bearing.
Keep the distance from that nut to the bearing housing less than an inch distance.
Should do the trick.
B. MacDonald
Sun Sep 16, 2012 4:52 am
Users browsing this forum: No registered users and 65 guests
