It is currently Wed Jul 23, 2025 6:38 pm
Reply to topic  [ 12 posts ]
 gtr reverse question
Post gtr reverse question
last week while using reverse on my gtr, ( i had been stuck in an area with only a few inches of mud and a hard bottom) my brake lever lost all tension, has been fairly hard to pull since the motor was new, but after using reverse and forward continously for a while and really putting the engine in a bind the reverse lever would pull all the way to the tiller handle, it would still engage the reverse but usually the reverse engages after about an inch of pull, i was able to pull it all the way. After a few minutes it went back to normal and still works fine.
Just seemed like it lost hydrualic fluid but then it came back.... has anyone else had this happen
gtr35 gt 1854 / w gatorglide
12 ft 11hp longtail
14 ft 10 hp longtail
Merc 225hp TR20
Sat Oct 06, 2012 6:04 pm
Post Re: gtr reverse question
You worked it hard enough to heat the brake fluid so much that it lost its viscosity thus lost pressure. I've done it twice in some nasty thick hyacinth, but it goes back to normal after it cools down. Thought I'd done screwed up big time, till Calen told me what it was.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sat Oct 06, 2012 10:25 pm
X2 only happened a couple times but i was working the reverse alot.
Sat Oct 06, 2012 10:28 pm
I thought I had screwed it up for sure but then it went back to normal, thanks for the insight
12 ft 11hp longtail
Merc 225hp TR20
Sun Oct 07, 2012 8:24 am
Sun Oct 07, 2012 8:26 am
Actually seen a prototype of that so may be coming soon
12 ft 11hp longtail
Merc 225hp TR20
Sun Oct 07, 2012 8:31 am
MMT Moderator
R&D never stops :mrgreen:
I've superheated mine a lot all I run is hard bottom areas.
GTB 1860 w/ 2019 GTR40XD-HO
Sun Oct 07, 2012 8:40 am
I've never had that problem, When you engage the reverse handle, squeeze it, don't half ass squeeze it cause it'll heat up tremendously, hence why some clutch covers melt. If you are reversing alot make sure when you squeeze you squeeze it to where there is no slipage
Sun Oct 07, 2012 9:10 am
Eat - Sleep - Hunt ! ! !
Sun Oct 07, 2012 9:19 am
Sun Oct 07, 2012 10:10 am
Sun Oct 07, 2012 10:12 am
I assure you, my PPR used to get overheated & quit working all the time!!!
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Oct 07, 2012 1:01 pm
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 162 guests
