It is currently Mon Aug 04, 2025 7:34 pm
Reply to topic  [ 11 posts ]
 go devil died today
Post go devil died today
well i was just letting my go devil run out in the shop today and after about 15 minutes it just shut down like someone had turned the key off.
it wouldnt even turn over.
my question is how prone are the key switches or kill switches to failure?
the reason i think it was either the switch or the kill switch is because the motor shutt off by its self and wouldn't even turn over after i had waited a while. i could hear the clicking when i turned the switch to run but it would do nothing when i turned it to start.i took the plastic off to get to the back of the key switch and checked for loose wires and then when i pluged it back in i nolonger heared the clicking when i turned the key to run.
25 hp kohler motor
thanks guys
Thu Aug 06, 2009 6:15 pm
Post Re: go devil died today
yes i did. the battery i used was my trolling motor battery that had just gotten off the charger and is only a month old.
so its not the battery
Thu Aug 06, 2009 11:13 pm
wiring can definitly be the issue.
Fri Aug 07, 2009 7:23 am
how can i check the selinoid?
i did put a wrench from the selinoid to the frame and that turned the motor over but i pulled it away before it would start. the second time i did that it blowed the fuse going to the started and would still trun the started but not engage it to the flywheel.
all the wires look to be fine so after i took the cover off i began wiggeling every wire i could find while holding the key to the START position... nothing
i thought i would beable to find the loose conection but no luck.
i bought a new key switch off ebay last night and it that dosent fix it then its going to the local small engin shop.
Fri Aug 07, 2009 10:29 am
ohm both ur switches and see if theyre working properly
cajun: its real simple, we live back hea', dis' is our home, an' nobody don' fuk wit' us!
Fri Aug 07, 2009 10:33 am
how do i ohm my switches?
Fri Aug 07, 2009 6:42 pm
ohm meter
Fri Aug 07, 2009 8:23 pm
Mine have always turned over even with a bad kill switch, if you pull the little thing that hooks on the kill switch, mine will turn over, just wont start. Sounds like a wiring issue somewhere. Does it have the mercury switch on it?
Just your basic cracka ass cracka
1840 gator tail with 35GTR
15xx Bateau with 15 honda
Sun Aug 09, 2009 7:27 am
Trace the wiring from the kill switch to the motor and check the connection. Mine vibrated a little loose one day on a ride and it took me forever to figure out the problem. Did exactly what you're sayin though, runnin fine and then it just killed.
18' Weldcraft - 90HP
1654 GD 35GDSD Bone stock, including a rusty exhaust.
The only time I've rooted for the crimson tide, my gf was 3 days late.
FOREVER LSU
Mon Aug 10, 2009 7:11 am
what is a mercury switch?
by the way thanks guys for being so patient and helpful
Mon Aug 10, 2009 10:32 pm
FOREVER LSU
Tue Aug 11, 2009 6:01 am
Users browsing this forum: No registered users and 105 guests
