It is currently Tue Jul 15, 2025 1:59 am
Reply to topic  [ 39 posts ]
 New prop for the prodrive
Post New prop for the prodrive
Once I get my carb ill be running a mikuni and double barrel marshmellow. My prop is the same prop from 06 according to previous owner. So it's in desperate need of a change.
Should I go back to stock?
Or if I want to go aftermarket I'm looking for a little better load carrying? Or top end
What size should I go with and where is a good place to get one from?
Thanks guys
Btw what is the stock 36hp prop supposed to measure?
2072 Gatortail extreme with dual 35s GTRs
Fri Oct 19, 2012 8:01 pm
Post Re: New prop for the prodrive
If you're only changing exhaust and carb stock will be good especially with a load.
Might consider going to a 13 pitch but with a load it may be worse
Pete Willett
WC Custom Boats - Tyler, TX
http://www.wccustomboats.com
Fri Oct 19, 2012 8:04 pm
Great! Thats what I thought. Makes it easy. What is the prop supposed to be?
Fri Oct 19, 2012 8:06 pm
I wouldnt say that you need a new prop just because the motor is a 2006. The prop on mine has been on for 275 hours and still runs just fine.
New prop should be around 12.25" I believe.
Fri Oct 19, 2012 8:07 pm
The reason I say it needs a new prop is because it looked small compared to what I have seen on other prodrives and now reading this forum it got me thinking.... Went out and measured a whopping 11.5... From what I'm reading I'm prolly not getting full potential out of my motor.
Fri Oct 19, 2012 8:10 pm
Haha yea it's time for a new one. Go with the stock Pro-Drive prop.
Fri Oct 19, 2012 8:18 pm
Awesome! Thanks again for your help
Fri Oct 19, 2012 8:23 pm
There is a new prop designed by merc coming out in dec/jan
GatorHide - MB
Sat Oct 20, 2012 11:14 am
Sat Oct 20, 2012 2:13 pm
What would be a good mud prop if I want to go aftermarket? Or should I still go stock
Sat Oct 20, 2012 2:37 pm
GatorHide - MB
Sat Oct 20, 2012 3:14 pm
And you thought that was relevant to a guy with a Pro-Drive why?
Sat Oct 20, 2012 3:57 pm
B/c it will be avail for all motors. Ass
Would you have been happy if I didn't say it was coming on the MB motors
Let me try again ..... Merc is comin out with a new mud prop for motors with reverse.
GatorHide - MB
Sat Oct 20, 2012 4:00 pm
B. MacDonald
Sat Oct 20, 2012 6:30 pm
Buzz killington livening up to your name....if my boat is going backward and my motor is the reason it's going backward then I call that reverse....
Sat Oct 20, 2012 6:48 pm
Sorry had to be a smart ass one time on a thread
Sat Oct 20, 2012 6:49 pm
Sat Oct 20, 2012 6:52 pm
Ok ignore my dumbass comments. I realize the relevance of buzz's comment. I got all worked up and was pre mature in my comment.
Hate when that happens! Haha
Sat Oct 20, 2012 7:05 pm
B. MacDonald
Sat Oct 20, 2012 7:30 pm
I was not aware that they were gonna make a threaded prop as well. My bad.
Sun Oct 21, 2012 6:59 am
Sun Oct 21, 2012 9:50 am
GatorHide - MB
Sun Oct 21, 2012 4:02 pm
Big blades don't fit the pd. Doubt the new prop will be any different if it ever even makes it to the market..........
Sun Oct 21, 2012 5:28 pm
Yea that hex big blade prop slides on the threaded shaft of the pro-drive, and has a nice snug fit.
Sun Oct 21, 2012 5:52 pm
2 things
MB would have to have a motor with reverse before they use it.
I might buy a sport v if they ever come out. I have always been a mercury fan and that is who is building the whole thing.
Sun Oct 21, 2012 5:59 pm
The big blade isn't enough prop for a PD. At 10P, it is no good for a PD.
18'x54"CC Hanko/ 36PD
Mon Oct 22, 2012 10:55 am
Its hard to beat a new stock PD prob. As CB said back when fighting with Hershey over the "Magic Prop", "the prop game is an expensive one".
Mon Oct 22, 2012 11:20 am
I said hell with it and bought a stock. Can't really go wrong like everyone said
Mon Oct 22, 2012 7:19 pm
Stock is good, I sent me old one to get recupped changed to a 13 pitch, it might be worth using as a trot line anchor.... With three guys and four ten foot gators the other night I was turning 4100 rpm and only running 20mph...sucked
Tue Oct 23, 2012 1:46 pm
What is the secret to getting this thing off! I can't get mine off
Wed Oct 24, 2012 6:13 pm
beer
Wed Oct 24, 2012 6:25 pm
I just got done installing a mikuni and a rev limiter with all my wires no longer color coded... It all working correctly by the grace of God... Beer sounds like a great Idea!
My prop nut came of. I'm going to call PRODRIVE and get the prop wrench and shaft locker thingy deal
Wed Oct 24, 2012 7:41 pm
no need!! a 2x4 with a 1" hole saw, drill a hole in the 2x4 to where is pushes on both blades.
a 6" 3/8 extension works in the collar to stop the spinning
if you had beer you would know this
Wed Oct 24, 2012 7:44 pm
1850 & 36pd
Wed Oct 24, 2012 9:10 pm
A three foot crow bar works wonders (if you have one), put the prop nut back on to protect the threads, the hook end of the crow bar wraps around one blade, anything that will give you leverage and will twist it. If it's been on there a while, it'll take some ass behind. You'll think your about to lift a trailer tire pushing on it.
When you put it back on make sure your put antisieze or good grease all over everything.
Thu Oct 25, 2012 4:26 am
B. MacDonald
Thu Oct 25, 2012 4:52 pm
6 inch 3/8 extension? Not following you?
Thu Oct 25, 2012 7:28 pm
3/8 inch drive ratchet extension. 6 inches long.
Thu Oct 25, 2012 9:49 pm
Oh I got you. I don't know what I was thinking.
Fri Oct 26, 2012 4:55 am
Users browsing this forum: Google [Bot] and 23 guests
