It is currently Tue Jul 22, 2025 2:13 pm
Reply to topic  [ 18 posts ]
 35 GTR blowing clutch fuse
Post 35 GTR blowing clutch fuse
I've got an 08 model and the last two times I've ran it I blew the fuse. The first time it was only a few min before it blew the second time maybe an hour. I was leaving for out of town the second time so I have not spent much time looking into it just seeing if anyone else has had this while I was still out. Thanks.
Fri Oct 26, 2012 7:27 pm
Post Re: 35 GTR blowing clutch fuse
Check for chafed or broken wire grounding out
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Fri Oct 26, 2012 7:33 pm
Yup definitely the first thing ill trace down and eliminate. Thanks
Fri Oct 26, 2012 8:06 pm
Change the fuse holder
17x48 extreme stage 2 GTR
Fri Oct 26, 2012 8:14 pm
I had the same problem, thats what Terry found wrong with mine.
Sent from my DROIDX using Tapatalk 2
Fri Oct 26, 2012 9:19 pm
Preciate the input. I'll do that as well and repost
Fri Oct 26, 2012 9:55 pm
Buy a GD no fuses to blow....
Sat Oct 27, 2012 5:58 am
That's true no fuses to blow only u-joints ( see cootslayer) :)
Sat Oct 27, 2012 7:17 am
still only happened once how many times has that fuse blown now? 3,4....
Sat Oct 27, 2012 7:52 am
Sat Oct 27, 2012 8:24 am
Sat Oct 27, 2012 8:44 am
I blow fuses in my truck periodically, so should I just buy a bicycle?
Sat Oct 27, 2012 9:37 am
Sat Oct 27, 2012 9:48 am
Every + line off the battery should be fused or protected from a direct short in some way on any motor. Not protecting the wire is a fire hazard and sure seems like a bad idea to me.
Sat Oct 27, 2012 9:52 am
Sat Oct 27, 2012 11:27 am
It's all good - he can just reverse all the way - or at least
until the plastic shroud bursts into flames ---- LOL
Eat - Sleep - Hunt ! ! !
Sat Oct 27, 2012 1:41 pm
Changed fuse twice, on the water, probably a good 10-12 seconds downtime.
Sat Oct 27, 2012 3:02 pm
$6 fuse holder will most likely solve my issue ( 4-6 min labor)
Sat Oct 27, 2012 3:04 pm
Users browsing this forum: No registered users and 139 guests
