It is currently Tue Aug 05, 2025 1:05 am
Reply to topic  [ 24 posts ]
 Clutch Disengageing on Pro Drive
Post Clutch Disengageing on Pro Drive
Has anybody ever had the clutch on a ProDrive click loud and disengage while running and not re-engage after that?
Thu Aug 13, 2009 9:17 pm
Post Re: Clutch Disengageing on Pro Drive
Nah, I had mine disengage from a slightly loose connection..but I was able to fix it in a sec and worked fine after that...
1754 GT EXTREME 37EFI
Thu Aug 13, 2009 9:18 pm
I told this person to check the wiring. I dont remember if there is a fuse in line or not so I told them to check.
I was asked to not mention who called from the swamp with this problem LOL
I do know they have a paddle :lol:
Thu Aug 13, 2009 9:25 pm
Just talked to 'em, gave a few things to look @ before usin' de paddle!
Thu Aug 13, 2009 9:27 pm
Thu Aug 13, 2009 9:34 pm
LOL I hope they not far from the landing????
Thu Aug 13, 2009 9:38 pm
They said they wasent close :shock:
Thu Aug 13, 2009 9:43 pm
We were approx. 17 miles away from landing..
We just started to frog.. Had about 20 when I stated to my dad, lets go in another pond. I never been in this one, and with the fog I dont want to get turned around.. THEN... As soon as we hit deep water.. CLANK !!! Clutch didnt work anymore.. I tested the switch to see if it was still working, and it was. I think the noice I heard may of been somthing sheering off in the clutch itself. Not sure..
Thanks to coon and brad for answering at 10+pm...
O.. one other thing.. If you were in a mudboat around Turtle Bayou last night, I hope you get very sick.. Not sick enough to die, but sick enough to realize that you shouldnt just passed on the side of me !!!
Me and My dad paddled 3 miles up current: then, some hoopnet fishermen pulled us to landing..I return, I had him follow me to the gas station, and I filled his 24 gallon tank up.. I also gave him one of my World Famous Catfish Stunners.(No, mine is not in a skoal can. It is in a Electric Tape case)
Fri Aug 14, 2009 5:51 am
Yeah that is pretty shitty how they didn't even stop to ask if ya'll were alright...But that was pretty good what you did for that guy, I've seen ppl get pulled all the way from shell Island to the berwick landing, and give that person a simple thank you...
Fri Aug 14, 2009 6:04 am
Glad to see ya made it in man.
Shit I figured that if you was callin that late you was either Drunk and id get a good laugh or you was stuck somewhere lol
Fri Aug 14, 2009 6:57 am
Man dat sucks... Hope It doesn't keep ya out fa long
Fri Aug 14, 2009 7:03 am
My dad is going get a clutch from Franklin Small Engine.. My Boat is already at Coons Shop.. If all goes well, hopefully I will be using it to put out a Deer Stand tomorrow.
PS.. I HAVE A F*$#^ BLISTER FROM HELL.. PADDLING SUCKS !!!!!
Fri Aug 14, 2009 7:45 am
:lol: dat sux!!! How long did you have to paddle for?? U didn't have a trolln motor?
Fri Aug 14, 2009 7:56 am
No trolling motor. Paddled for about 2 hours or so...
It was some really nice Father/Son time.. :D
Fri Aug 14, 2009 8:35 am
A friend of mine and his padna went fishing already and the prop mysteriously came off of his outboard. No paddle in da boat.. Dey had to jump out and swim da boat back to da launch fa two hours!!! :lol: at least u r smart enough to keep a paddle in da boat unlike dem yonks
Fri Aug 14, 2009 8:53 am
That would have sucked... They alligators everywere last night...
Fri Aug 14, 2009 8:55 am
broken ground wire was de culprit :lol:
Fri Aug 14, 2009 3:45 pm
Yep that will do it....I just had the wing nut on my battery a lil' lose one night and it done that to me....
Fri Aug 14, 2009 4:57 pm
Glad to see ya back up and runnin
BTW Didnt I tell ya to check the wires :mrgreen:
Fri Aug 14, 2009 8:41 pm
food for thought.
when the clutch goes out, it's usually the bearing seizing up and u will know it cuz it will make noise and get hot as a firecracker before it melts the wires in two.
if it just quits working it's usually either a bad ground or a wire has come off the switch.
if ur battery goes dead it will turn loose as well.
Fri Aug 14, 2009 9:12 pm
GOOD DEAL !!!
I hope others can learn from this.. ALWAYS CHECK WIRES !!!
Sat Aug 15, 2009 3:01 pm
Where is the clutch ground wire? I assume it grounds to the frame/block somewhere instead of running to the switch or battery.
Sat Aug 15, 2009 8:31 pm
grounded right next to the starter on one of the case bolts. Atleast it was on mine.
Sun Aug 16, 2009 10:19 am
Mine was grounded behind the engine. If you look from the back, you will see two wires that ground to the framing.
Mon Aug 17, 2009 6:25 am
Users browsing this forum: Google [Bot] and 85 guests
