It is currently Tue Jul 22, 2025 12:05 am
Reply to topic  [ 29 posts ]
 Best motor For hard sandy bottom, and stumps?? * READ*
Post Best motor For hard sandy bottom, and stumps?? * READ*
Been running pro drive for about a year now and just sold my rig. about to start new build and am pondering the idea of moving to gator tail. spoke with willet the other day and he said he thought the GT were better in the hard bottom. because of the angle of the drive. Which made me think of all the times my boat would be floating fine but the skeg on my pro drive was dragging bottom. keep in mind I had the manual trim and could only trim up so far but by that point had barely any prop in water, and didnt want to eat the prop up. So with that I am considering making a change. BUT I have grown used to the confidence in the gear drive system. Always been afraid of belt drives. Also learned that the GT is about 100 lbs lighter which is a big deal considering I like to get in the skinny shit. and running these east Texas stumps, the less draft the better. But is the GT lower unit as tough as the PD?? Undecided?? Some of you more experienced guys chime in here and Give me some EXPERT advice
Tue Dec 04, 2012 9:29 am
Post Re: Best motor For hard sandy bottom, and stumps?? * READ*
You can always cut the skeg down on the PD, or just get an airboat.
35 GTR - 1754 Extreme
Tue Dec 04, 2012 9:41 am
Step away from the Koolaid!!!! :lol:
Dont be afraid of a belt though,,,that lill engine aint got enough powa to break dat...
Tue Dec 04, 2012 9:47 am
1850 Uncle J
Delta Performance level 4 GTR
Tue Dec 04, 2012 10:12 am
First off, I wouldn't worry about the GTR belts. They are tough as chit, I am on my original belt. The GTR LU's are tough. I busted my prop shaft last year, but I also towed in several PDs and outboards with shredded gears or busted LUs. I have seen less failures in the GTRs vs the PDs drive units. I think that can be attributed to the fact that the belt will absorb shock better than gears. I also prefer the GTR in hard shallow bottoms, although if you really want the best in hard bottoms, LTs are the way to go. Also let me add that when I broke my prop shaft last year, I was beating the hell out of it all day everyday. AND, my skeg was worn about an inch or so, therefore my prop did not have protection against strikes.
1854 Sportsman's Fab
2046 Uncle-J Skiff
35 GTR
Tue Dec 04, 2012 11:26 am
This is good info... keep it coming. I have busted the shit outta some stumps with prodrive and all I have done was broke the prop. Buuut every time i smash one I would look back thinking my transon was ripped off. They way the thing is balanced the lower unit takes a hell of a beating. I'm not too concerned with the belt itself just the shaft housing on the GT. It just looks weaker to me. But I like the points you guys have made.
And Im not running a longtail on a 19'x54" lol I'm building a center console so I can get away from the tiller.
Tue Dec 04, 2012 11:40 am
2046 Uncle-J Skiff
35 GTR
Tue Dec 04, 2012 11:45 am
Godevil...just sayin :lol:
Tue Dec 04, 2012 11:46 am
if shallow hardbottom area use a longtail or a balanced motor.
or if you want to be really cool get a jet boat
27 Contender twin 200's
for sale
Tue Dec 04, 2012 12:54 pm
Hes getting a center console which automatically rules out a balanced motor
1850 Uncle J
Tue Dec 04, 2012 3:42 pm
copperhead :roll:
Tue Dec 04, 2012 6:00 pm
17*38 Klibert 23GDLT
Tue Dec 04, 2012 6:11 pm
1850 Uncle J
Wed Dec 05, 2012 12:12 am
1850 Uncle J
are yall referring to a GT when you say balanced motor? and brasso how does the center console rule one out??
Wed Dec 05, 2012 8:30 am
If you have a center console your gunna have a motor with trim
Wed Dec 05, 2012 8:42 am
ya I know I guess by balanced motor they mean a go devil sd. I have only seen one in person and didnt recall seeing a trim unit. But I know you could lift it with one finger. But I think I'm leaning towards gatortail now. Just wish I could find a used one so I could afford to do some mods. Does Gatortail do mods from the factory?
Wed Dec 05, 2012 8:57 am
1850 Uncle J
Wed Dec 05, 2012 9:04 am
waiting to here back from him.
Wed Dec 05, 2012 10:15 am
You should take one for a spin first in the area you run and see how it does.
Wed Dec 05, 2012 10:54 am
for sale
Wed Dec 05, 2012 10:41 pm
Ive ran both, and both get stuck in shallows with a hard bottom if you dont have momentum. Sand, doesnt matter if you have momentum or not, its all gonna stop.
1850 Uncle J
Wed Dec 05, 2012 10:59 pm
Thu Dec 06, 2012 6:58 pm
Go devil SD
Mallards fetched by Fox Red Lab from RBK Brittish Kennels
1648 Monark w/ GDSD 27
Want a Gatortrax 4 man gatorhide w/ Mudbuddy 45 mag
Sat Dec 15, 2012 5:16 pm
I know what you are saying about the skeg dragging bottom. I run PD and I believe we run the same areas. With the GT being lighter and the decreased angle of the lower unit it would probably be more efficient. 100 lbs is a lot of weight difference considering it is hanging off the back of the boat.
Semper Fi
16x38 WC Skiff 35 MB HD
Wed Dec 19, 2012 3:37 pm
Don't ever be afraid of a belt drive. I've had chain, shaft, and belt driven motorcycles and I've got a gator tail that I've brought through the worst stuff I could find in every situation and I'll take the belt an day!
Wed Dec 19, 2012 8:42 pm
Youve gotta remember a belt has give in it... its a gigantic rubber band, which absorbs some of the hit and puts less stress on your drive.
1850 Uncle J
Wed Dec 19, 2012 11:05 pm
The PD manual trim has left a bad taste in your mouth as it should have, it sucks. The hydr trim is a night and day difference with more stroke or actual upward trim that will keep the skeg from dragging all the time. With a hard bottom and on step you just trim it up just to where it stops bouncing and drop the hammer on it. It will also get you out a hard bottom situation better in reverse trimmed all the way up than the Gtr. But with that said if the area I hunted was all hard bottom than the Gt is the right way to go and they are tough just make sure you check the L/ U upper knee brace bolt from time to time to make sure it's tight. That's the only thing that I have seen to put a hurtin on the L/U drive tube. Best thing IMO is like mentioned above and that is get someone with a GTR but also with some tiller time and ride with them in your area. Your not going to be able to switch brands and drive it like a boss first time out! There's a learning curve that goes with em.
Wed Dec 19, 2012 11:41 pm
Nothing will do better on a hard shallow bottom than a longtail.
Seen one niggerrigged with an old paragon 1 to 1 clutch behind it.
This heavy clutch on the back made it a "weighted back" design.
It was rigged with pulleys and cables on a cathead style steering wheel.
It didnt go very fast but the old man was never in a hurry anyway.
Was on a wide 18 foot flatboat and rigged for floundering.
We welded an extra skeg on it and u could idle around in water a lil
More than ankle deep, over solid sand bottom all night long.same prop
On it 2 yrs for sure.......prolly couldnt get it off that rustbucket with a
Fukkin torch anyway.lol.
Thu Dec 20, 2012 1:21 am
Users browsing this forum: No registered users and 87 guests
