It is currently Mon Jul 14, 2025 4:24 am
Reply to topic  [ 15 posts ]
 Gdsd 23 2 or 3 blade
Post Gdsd 23 2 or 3 blade
Ive got a 23 gdsd with a 2 blade and it just dont seem to run as fast as it should my buddy with a 20 gdlt can out run me both of us unloaded i was wondering if a 3 blade would be better
1440 xpress 23 gdsd... Sold
1644 gd 35 gtr
Thu Nov 08, 2012 5:26 pm
Post Re: Gdsd 23 2 or 3 blade
Three blade is supposed to be faster i believe. With better holeshot. I have a 3 blade 23 Hp gdsd. What kind of boat are u running? How many rpms is your engine getting at wot?
Thu Nov 08, 2012 9:36 pm
How old is your prop? It could be worn out
Thu Nov 08, 2012 9:38 pm
You need to change your pulleys to get the right gear ratio - BEFORE
you can run the bigger higher pitch 3 blade....
It is worth the effort though - I have seen the side by side difference
on the same hull....
Call up GD with your frame SN and they can line you up with what you
need to make the transition properly...
Eat - Sleep - Hunt ! ! !
Thu Nov 08, 2012 10:35 pm
Its a 15 48 weldbilt and its turning right at 4000
1644 gd 35 gtr
Fri Nov 09, 2012 6:33 am
I would like to try a 3 blade but I don't have a GD. Does anyone else make them for 3/4x10 threads?
1846 GTB and 35 GTR
New GT Rig
Old Surface Drive Build
Fri Nov 09, 2012 7:13 am
Fri Nov 09, 2012 8:12 am
Fri Nov 09, 2012 2:00 pm
I got the governor tab bent and its puts it in a bind with three ppl
1644 gd 35 gtr
Fri Nov 09, 2012 4:36 pm
I have the three blade and I cannot turn 4000. Even outta the water. When I first got the engine I had it trimmed all wrong and I could barely get 3300 in water. I figured that out and now I turn 3650 with 2 people. Max
Fri Nov 09, 2012 8:57 pm
1846 GTB and 35 GTR
New GT Rig
Mon Nov 19, 2012 7:38 am
Does anyone no how to tell the diff in an old style and a new style the gd website says u have to retrofit the opd style to run a 3 blade on it
1644 gd 35 gtr
Tue Jan 01, 2013 2:44 pm
Call GD with your frame SN - they can tell you everything ! ! !
If you have a 10 inch 2 blade - it's the old style ! ! !
The 3 blade is 11 inch and the bigger 2 blade made for the
35 GDSD is a 12 inch diameter.
Tue Jan 01, 2013 3:10 pm
Is the serial number the tag riveted to the shroud around the engine or is it somewhere else
1644 gd 35 gtr
Tue Jan 01, 2013 4:00 pm
Your frame SN - is stamped into the outdrive frame about
12 inches from the prop in 1/4 inch tall numbers... It's
also on your Texas Title paperwork...
Tue Jan 01, 2013 4:41 pm
Users browsing this forum: Google [Bot] and 30 guests
