It is currently Mon Jul 07, 2025 3:49 am
Reply to topic  [ 13 posts ]
 23hp mud buddy...how do I mount this to my transom?
Post 23hp mud buddy...how do I mount this to my transom?
I've searched and I'm having trouble finding the answer. I picked up the used mud buddy mentioned in a previous post yesterday and need to figure out how to mount it.
The mount it came with has a small lip that goes over the transom and two holes on the back side of the transom to run bolts through. Are there any mounts out there that just clamp on? I really don't want to drill holes in the transom if I can avoid it, especially since I don't even know if I'm going to like this setup on my boat yet. I can probably get some pictures if I need to.
Thu May 23, 2013 10:29 am
Post Re: 23hp mud buddy...how do I mount this to my transom?
You would be better off bolting through your transom i wouldn't trust a surface drive motor that is just clamped on with the kinds of terrain these kinds of motors run in.
Stage 2 36 HP Pro-Drive FPR W/ Bayou Boys Custom Skeg,Cave Plate,and Weed Cutter with MAC Exhaust
Pushing a 17X54 Pro-Drive X-Series boat
Thu May 23, 2013 10:32 am
Thu May 23, 2013 10:33 am
Bolt the motor on! If you can keep a mud motor on the transom with Only the clamps, you probably don't need a mud motor. But it's your motor you do what you want. I've seen a few motors fall off
Does anyone have a picture somewhere of a longtail mud buddy transom mount? I just want to make sure this is original equipment and I'm not drilling holes where they shouldn't be in case I have to replace the mount at some point.
Thu May 23, 2013 10:49 am
Holes can be welded alot cheaper than buying a new motor because its at the bottom of the lake! Take a picture so we can see the mount.
Thu May 23, 2013 10:58 am
Bolt it on. I know someone that tried to clamp one on and he lost him motor.
Sent from my SAMSUNG-SGH-I777 using Tapatalk 2
Running a Alumacraft 1442 NCS with a 25 HP Orion surface drive. Not the best, but it works.
Thu May 23, 2013 11:12 am
Godevil longtails have been clamped for years.
Put up a picture of your mount
Mon May 27, 2013 6:06 am
Tue May 28, 2013 5:52 pm
I bolted a 23 mb long tail and never lost it i would recommend Bolt it on!
Tue May 28, 2013 6:03 pm
Bolt it....
Tue May 28, 2013 6:24 pm
Got tired of thinking about it so i just went out and bolted it up. Think a piece of plywood is ok right there? Had to fill the space with something.
Tue May 28, 2013 7:56 pm
Users browsing this forum: No registered users and 34 guests
