It is currently Mon Jun 30, 2025 2:43 pm
Reply to topic  [ 15 posts ]
 Stock 6.5 mad mud motor?
Post Stock 6.5 mad mud motor?
Is there anyone here that has tried the stock predator 6.5 on a mad mud motor plan built longtail?
It seems most people here are looking for more speed, and I can understand that for most situations. I am just curious if anyone has tried this set up. I have a little hunting cabin in the woods of northern MN. There is a 385 acre wild rice lined lake at the cabin, and that is the only water I ever use. At present I have been using an old johnson 3 HP twin outboard and it actually gives me plenty of speed, a screaming 3 MPH! Only drawback is, I have trouble getting into the rice bed that holds the best duck hunting with it. I am hoping the mad mud motor will get me back in there a bit further. I will be running it on an old 50s model alumacraft 12 foot that is very narrow and light. I also use a light 14 foot sears cartopper. My question is, do you folks think I will be able to get at least the same speed from the 6.5 mud motor, that I was getting from my vintage 3hp outboard and at the same time get into the rice beds farther? There really is no mud flats on the lake. Probably the shallowest it will ever see is a foot of water.
Thanks,
Jim
Sat May 11, 2013 10:58 pm
Post Re: Stock 6.5 mad mud motor?
I tested my new 6.5HP GDLT yesterday, mounted on a 12' Springbok which is very much like a V-bow, flat stern cartopper.
Rpm out of water 3870, in water 3450. With just one person and a starting battery, say total load weight 200lb, my top speed was 10 mph measured on a Garmin GPS. This is way faster than my 3HP Johnsons and Evinrudes.
6.5 HP GDLT/ 12' Springbok or 15'4" Gheenoe or TDB Classic 14'
Sun May 12, 2013 4:19 am
Pinepointer, You have made my day!
I will be happy with half that.
Sun May 12, 2013 8:55 pm
Mon May 13, 2013 10:20 am
B. MacDonald
Wed May 15, 2013 5:47 pm
That's my Plan B.
Plan A is the 16HP GDLT and 16' Scott Duckboat.
Wed May 15, 2013 6:36 pm
Might want to look at the eBay kits for the small longtail kit for the 6.5 for 400 or the mini kits for the 2.5 for alittle less, dont know how much u plan on running it
Thu May 16, 2013 8:28 pm
Tue May 28, 2013 6:47 pm
I want to put a animal race motor on my pirogue
Tue May 28, 2013 7:11 pm
Friar,
I am in the same process, building the mount now. I used the predator.
Will know in a week or two how it oans out. I am in the same situation in Northern MN with all rice areas. I think these longtails are the only way to cut through the real thick stuff.
I am looking at a hop up kit from NR Racing online. You can add about 4 hp for a $75 kit pretty easily. Good option if you don't get the speed you want but I think you will be fine.
Where in MN are you?
Tue Jun 04, 2013 9:40 pm
ImageUploadedByTapatalk1370411379.624847.jpgImageUploadedByTapatalk1370411393.189539.jpgthese are my plans one of these days
Tue Jun 04, 2013 11:50 pm
Sat Jun 15, 2013 8:42 pm
I have a predator 6.5 on a mad mud motor. I have a 1436 tracker and with 2 people and gear I stay around 5-6 mph. Empty as fast as 9 mph. I would like to jump up to next size prop. Probably pick up an mph or 2.
Mon Jul 01, 2013 8:04 pm
I had the 420cc harbor freight and finigled the mad plans and came out with 16 mph with 2 people.
35 GTR chasin a BBC 1848
Mon Jul 01, 2013 8:12 pm
i have a 6.5 gdlt and can run around 8-9mph with two people dog and gear. I have a pic somewhere on here. different air filter and exhaust. cranked up the rpm also
Thu Aug 08, 2013 3:56 pm
Users browsing this forum: No registered users and 59 guests
