It is currently Tue Jul 15, 2025 8:35 am
[ 7 posts ] |
PD kit for 1 pump.... 2 cylinders
banded-mallard
Finally got call back from KP. The kit will not work with the older PD's with the older mercruiser trim pumps. You have to have the new Bucher trim unit to make it work. So fuck me, but I'm still looking into the hydraulic selector valve to seperate the two.
Mon Jul 08, 2013 2:46 pm |
dualpds
Joined: Sun Aug 19, 2012 4:06 pm Posts: 72 Location: Neenah, WI
 Re: PD kit for 1 pump.... 2 cylinders
What part of the new system won't work? The switches?
Mon Jul 08, 2013 5:02 pm |
CCC
I hydraulic unit is a hydraulic unit. As long as it has a supply/return/and up and down switch it should work with any unit. Might have some different fittings you will have to change. I'd like to see a picture of the new set up
Mon Jul 08, 2013 5:06 pm |
Gameover
Joined: Tue Jan 03, 2012 9:06 am Posts: 3673 Location: Prarieville,LA
it may require custom hydraulic lines but i too dont see why it cant be done.
_________________ 1754 GTR Xtreme CC w/ Purple Kool-aid Additives
Tue Jul 09, 2013 6:18 am |
naj
Joined: Fri Jan 22, 2010 8:40 pm Posts: 1620 Location: Larose, Louisiana
This was on that flyer someone posted on the other thread.
I would like to know what that Selector Switch is. Do I have to actually select what ram I want to use or is it an automatic function that changes with what switch you use. ImageUploadedByTapatalk 21373380329.262180.jpg
_________________ 18' X 48" Center Console Sportsman Fab with a Yamaha F70LA 18' X 48" Center Console Sportsman Fab Dragging a 36hp ProDrive 15' X 42" Sea Arch with a 27hp ProDrive
Tue Jul 09, 2013 8:32 am |
Quackhead62
Joined: Fri Nov 30, 2012 7:47 pm Posts: 931 Location: Maurice,La
i think it automatic you shouldn't have to flip any kind of switch to go from one function to the other. It is probably a NC contact then once you hit the switch for which ever function it sends power to the NC contact to open to let the hydro fluid flow to trim up or to go into reverse
_________________ Stage 2 36 HP Pro-Drive FPR W/ Bayou Boys Custom Skeg,Cave Plate,and Weed Cutter with MAC Exhaust Pushing a 17X54 Pro-Drive X-Series boat
Tue Jul 09, 2013 8:46 am |
banded-mallard
Tue Jul 09, 2013 10:24 am |
[ 7 posts ] |
Users browsing this forum: No registered users and 34 guests |
