It is currently Wed Jul 16, 2025 1:37 am
Reply to topic  [ 8 posts ]
 Need some GTR help
Post Need some GTR help
I got tasked with bringing my brothers boat to Gatortail to get worked on, needed bearing work and upgraded the reverse to gen 3 while it was there. Picked the boat up and took it out saturday for a ride, all went well. Got home and noticed these bolts hanging from the clutch cover. Pulled clutch cover off and I am pretty sure these bolts go with the bracket that holds the caliper. Anyhow, I would throw it all back together but I am afraid the nuts maybe at the bottom of the belt housing, they are lock nuts so I doubt they would back off on there own. In the case they were only hand tight and fell to bottom of belt housing should I leave them there or tear everything apart to retrieve them.
Tue Jul 30, 2013 7:19 am
Post Re: Need some GTR help
Your brother gonna be mad at you!! But stick to that story and don't deviate! :)
Sent using Morse Code from my not so smart phone.
Tue Jul 30, 2013 10:48 am
I'm no rocket scientist but I wouldn't leave chunks of metal near moving mechanical parts for sure.
1754 Gator Tail Extreme
I like methanol, bring it
"I'm just a squirrel trying to get a nut..."
Tue Jul 30, 2013 10:55 am
Looks like they've got new hardware on there. Those could be the old bolts they took out and accidentally left in there.
Tue Jul 30, 2013 10:56 am
I'd definitely check in the belt housing for the nuts though
I cant see anything in the belt housing, and if they are in there im sure im going to find them under the sprocket and belt. Its SS hardware so a magnet is a no go. I talked to GT and they said throw some nuts on there and run it or bring it in and they will look over it. I just hate to take off from work to make the drive.
Tue Jul 30, 2013 11:42 am
1744 WC Custom
25 GTR
Tue Jul 30, 2013 4:01 pm
Loosen the 4 nuts (1/2") that hold the engine to the frame. Then remove the nuts holding the outdrive to the belt housing (9/16"). Pull the outdrive off, fish out the 2 lost nuts, put it all back together. Looking at 30 mins, tops.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Jul 30, 2013 8:53 pm
Users browsing this forum: No registered users and 39 guests
