It is currently Wed Jun 25, 2025 5:29 pm
Reply to topic  [ 7 posts ]
 27 HP PD no spark either side.
Post 27 HP PD no spark either side.
Have a problem with my motor. I have replaced the ignition switch and spark plugs. Starter will turn but no spark is produced from either side. checked continuity of kill switch and seems to be fine. Any sugestions?
Fri Oct 23, 2009 7:13 am
Post Re: 27 HP PD no spark either side.
If the kill switch circuit was bad you wouldn't even be able to turn the motor over.. Hard to believe BOTH coils went out at the same time.. I'm not familiar with the Kohler ignition system so call KP or Peck and see what they have to say.
"I just want silence. Jesus, it doesn't mean I don't like you. It just means right now, I like silence more."
Fri Oct 23, 2009 10:28 am
Yeah it don't make since that both went out. I started it let it idle then died. started then died. then nothing. I looked at the kohler manual and i'm trying to find out what the Spark Advance Module(SAM) does. its that little box on the side of the motor that both power packs feed from. Workin days right now so i can't call peck, i figured I'd post on here to try and learn as much as i could to help me out when i am able to holla at him.
Fri Oct 23, 2009 10:58 am
Fri Oct 23, 2009 11:03 am
Same thing happened to my 27, lawn mower mechanic said SAM was bad. Had choice of SAM for $128 or new style coils for $180. Had new coils put in. Running without SAM now. KP or Peck could probably advise ya best.
1754 PD Center Console, 60 Yammy, w jack plate
Fri Oct 23, 2009 11:56 am
well I think that what the problem is going to be. Did you gain anything by deleting the SAM? eisier start, higher idle speed ect...
Fri Oct 23, 2009 12:16 pm
No, it just ran better. It was actually turning over and backfiring, then starting. really weird. Your issue may not be the exact same. The SAM is built in to the new style coil.
Fri Oct 23, 2009 1:01 pm
Users browsing this forum: Google [Bot] and 136 guests
