It is currently Mon Jun 30, 2025 3:59 am
Reply to topic  [ 19 posts ]
 honda go devil
Post honda go devil
anyone messed with the 22hp Honda? godevil says it has lots of power
Wed Sep 18, 2013 3:18 pm
Post Re: honda go devil
For what sized boat?
1436 Lowe
Wed Sep 18, 2013 5:49 pm
16x40 skiff id use it for crawfishing and trapping didn't know how much power it had for the lillys and stuff like that
Wed Sep 18, 2013 6:05 pm
How much weight will be in the boat? Did you ever get the video I sent you?
23 swomp/ 1542 tracker
Wed Sep 18, 2013 6:43 pm
Yes I got it and it will be weighed down alot
Wed Sep 18, 2013 6:47 pm
If it can hold the weight I'd go bigger. The 22 will push it fine with you solo until you start adding weight, especially if you're gonna be fishing it a lot
16/42 crawfish skiff - 31GDLT
Wed Sep 18, 2013 6:52 pm
What about the 35 does it go through the thick Lilly good? I have a 35 surface drive right now and it sucks to fish with in the lilly
Wed Sep 18, 2013 6:59 pm
I've got a 31 and its a beast in the thick shit, if you can hang on it will go.. I had a 20 and 23 before that, night and day difference!
Wed Sep 18, 2013 7:12 pm
I might try it out cause the surface drive works the dog shit out of you in the Lilly and you can't work it like the longtail. I've drove a 31 before but just in open water
Wed Sep 18, 2013 7:16 pm
I am telling you. I call the 23 I am running an environmental devastation. This thing chews up vegetation so much. The 35 will be a beast. Woodie has got some good video on here. I am running the same stuff but taller lilies. You will be fine as long as you don't overload the boat. What happened to the backh20 option?
Wed Sep 18, 2013 7:23 pm
im just lookin into both of them I still have my surface drive I would need to sell that before I do anything
Wed Sep 18, 2013 7:25 pm
How much you want for it?
Thu Sep 19, 2013 6:30 pm
Probably 3000 I just shaved the heads ported the intake and put a brand new mud buddy big blade prop
Thu Sep 19, 2013 7:12 pm
The 22 Hp Honda is actually more like a 27-28 (gross hp). Honda started rating their engines by "net HP" all the other manufacturers go by "gross hp"... Google it...
2008 23hp GDSD w/ BPS crossover, Mikuni carb, and Big Blade prop pushing a 2008 16x48 GDSD boat.
Mon Sep 23, 2013 9:03 pm
Bobbymc is correct. All other manufactures us the j1940 test which is gross hp. This changes my thinking on next longtail purchase.
Tue Sep 24, 2013 7:59 am
I've been told some of the Honda's require 12v pover for the electronic ignition. If the battery is dead the motor won't run unlike the B&S which you can use the recoil battery or not.
Thu Oct 17, 2013 11:19 am
I replaced my 16 BS with a honda 630gx (20hp) this year on my GDLT. I have 40 hours on it and it has been great. The only thing I did to it was cut the plunger off the fuel shut off solenoid and disconnect the power to it. I run it on a 1448 and 1848 rivited alumacraft. Not a speed demon but it will get me where I want to go. I get 14-17mph depending on the load. Had it out yesterday and it was 28 degrees and it started and ran just fine. Winter weather advisory up here in Northern MN all week. We will be busting ice soon enough...
Sat Oct 19, 2013 8:00 pm
40HP Gatortail
Sat Oct 19, 2013 11:00 pm
Honda is much heavier. Might take that into consideration
17*38 Klibert 23GDLT
Sun Oct 20, 2013 10:55 am
Users browsing this forum: No registered users and 44 guests
