It is currently Sat Jul 12, 2025 4:08 am
Reply to topic  [ 22 posts ]
 PD trim busted / customer service
Post PD trim busted / customer service
08 PD
Not sure what you call the actual part. Its the round cylindrical piece between the arms that the actuator shaft slips in and a bolt goes through the piece and the actuator shaft. I have the part coming . Do I have to remove the motor from the transom bracket to get the arms off before I can remove the pins and c clips before I can get this broken part out?
Kudos to PD customer service once again. Part coming at no charge! 8-)
Mon Sep 23, 2013 7:54 pm
Post Re: PD trim busted / customer service
Nope!
Mon Sep 23, 2013 8:01 pm
Top roller, and yes you'll have to suspend the motor and remove the trim arms/bracket to replace it.
Mon Sep 23, 2013 8:02 pm
Mon Sep 23, 2013 8:03 pm
Maybe I'm thinking wrong, but I had the bolt that holds the actuator shaft break, and I replaced it without removing the engine.
Mon Sep 23, 2013 8:29 pm
Bolt is fine . The part the bolt goes through broke.
Mon Sep 23, 2013 8:40 pm
I understand that, but if I was able to remove the bolt, then you should be able to remove the piece that that bolt attaches to the shaft.
Mon Sep 23, 2013 8:45 pm
I took a pic. gimmy a sec
Mon Sep 23, 2013 8:49 pm
Mon Sep 23, 2013 8:52 pm
^^^ that's impressive. Did it happen on the water or trailer? I imagine it was worn pretty good.
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Mon Sep 23, 2013 8:53 pm
Was running alot of stumps (always running stumps) sunday teal hunting. May have contributed but, It broke yanking the rig out of a muddy boat launch and it bounced in a big pot hole. BOOM
Mon Sep 23, 2013 8:57 pm
WOW!
Mon Sep 23, 2013 8:59 pm
Water was about 6 inches deep and I could definately see if some one were to bust one in the shallows it would have been a bear to handle!
Mon Sep 23, 2013 9:01 pm
Shit, I dont remember how that pin works that holds that part in. If the forks have to be pushed outwards on each side to get it out, then yes you will have to suspend the motor.
For some reason I thought I remembered it being able to slide out one side, but now I think I'm wrong.
Mon Sep 23, 2013 9:02 pm
Mon Sep 23, 2013 9:04 pm
It is machined down on each end to go through the arms then the c clips pop on it. I reckon
Mon Sep 23, 2013 9:05 pm
I'm WRONG!!! lol
Miller lites flowing nicely watching Monday Night Football.
Mon Sep 23, 2013 9:08 pm
Mon Sep 23, 2013 9:14 pm
That is the old style (small) roller they used when they first introduced the hydr trim. They have since upgraded to a larger one.
Mon Sep 23, 2013 10:46 pm
Tue Sep 24, 2013 4:49 am
Tue Sep 24, 2013 6:17 am
Parts sitting on porch when I get home today. Ordered them yesterday ,and I am at the top end of the state! Once again, customer service at its best. Thanks KP
Time to go to work on the motor.
Tue Sep 24, 2013 4:03 pm
Users browsing this forum: No registered users and 116 guests
