It is currently Wed Dec 24, 2025 10:39 am
Reply to topic  [ 14 posts ]
 Mud motor for 1436 welded triton?
Post Mud motor for 1436 welded triton?
So I've decided to look into getting a mud motor for my welded 1436 triton. I currently have a Suzuki DF20AES 20hp outboard that weighs about 105 lbs. I've never had a mud motor so I'm not sure what HP I should be looking into. I usually hunt alone or with a friend and my dog. I have boat rides that vary from 1-13 miles on open water/ sloughs. I'm concerned about the weight of a surface drive so I've also looked into welding floatations pods to my boat to help out. Due to some of my longer boat rides if was wondering What would be a good motor to get decent speeds and have enough juice to carry 2 guys and a dog. Thanks for any input and help !
Wed Oct 02, 2013 9:25 pm
Post Re: Mud motor for 1436 welded triton?
I know a guy that ran a 18hp copperhead on a 1436. It ran good and wasn't too heavy In the back end.
I wouldn't put pods on it. I have put some on 2 boats with outboards and mud motors. The only thing that I see they do is pick the back end out of the water while sitting still. Lost 3 mph on the mudmotor and out board plowed horribly.
I believe the 18 would be a decent motor for that size boat.
Sent from my beeper.
Wed Oct 02, 2013 9:31 pm
Thanks! I was worried about it sitting to low in the water and not getting on a plane since a mud motor would most likely be heavier than my outboard I have now. What kind of speeds would an 18hp get ? I'm not looking for a ton of speed just want to be able to access areas that an outboard can't.
Wed Oct 02, 2013 9:35 pm
18hp or a 23hp theres only 4lbs diff. The bad thing is the boats just not big enough to get all the preformance out of the motor. I would guess ya would run 22-24 mph depending on weight in the boat. I ran a 14-36 with a 23 on it. I would run 21mph no matter how it was loaded. It was a old Boat the motor killed the boat after 1 season it was not welded thou.
Thu Oct 03, 2013 6:18 am
if you look the 18 is heavyer
Sat Oct 05, 2013 2:16 am
jb27, your boat looks pretty stout, I would put a 23 longtail on it and it would go through anything.
Mon Oct 07, 2013 3:41 pm
I have a 16 gdlt on my 1436 and i like it
Mon Oct 07, 2013 3:51 pm
18 would be best
Thu Oct 10, 2013 3:13 pm
That boat looks wider than 36. 23 copperhead way to go.
Thu Oct 10, 2013 6:45 pm
Id like to put a 23 on it but think it might be a bit much. It's a a welded 1436 16" transom. Just worried about the weight and drafting to much water in the rear.
Fri Oct 25, 2013 12:13 pm
I'm running a 25 hp Orion on a 1442 alumacraft and getting 24 mph by myself. Never get water over stern when I slow down. Weight of motor is fine.
Running a Alumacraft 1442 NCS with a 25 HP Orion surface drive. Not the best, but it works.
Fri Oct 25, 2013 3:45 pm
You will be much happier with a SD for long runs. IMO.
Fri Oct 25, 2013 3:47 pm
I've heard long tails are harder to drive however can pretty much go through anything and have lower top speeds than the surface drives do. I hunt sloughs and flooded ares with stumps and rocks etc. I also hunt tidal marsh to where it's straight mud. Kinda torn which would be best. Some of my boat rides are a few miles and one is 13 or so..here's a pic of my boat blind with a few buddies in it
Wed Oct 30, 2013 2:43 pm
A 23 long-tail is heavier than the copperhead SD but if you run alot of stumps the long tails are better.
Longtail props are more rounded and glance off stumps much better.
Wed Oct 30, 2013 5:52 pm
