It is currently Mon Sep 08, 2025 2:04 am
Reply to topic  [ 34 posts ]
 23 Go Devil SD boat?
Post 23 Go Devil SD boat?
Getting a new rig for this duck season just picked up a 23hp go devil sd and was wondering what size boat you would recommend? Iv been looking at lowe, g3 and alumacraft some are all welded and some are welded with rivets. Thanks chad
Tue Oct 15, 2013 6:34 pm
Post Re: 23 Go Devil SD boat?
Don't go cheap on the boat. I did and it is falling apart. Already looking at a costum and I have only been running my boat and motor about 10 hours
23 swomp/ 1542 tracker
Tue Oct 15, 2013 8:06 pm
It says this motor will go 20 to 23 on the website but idk if thats with a full welded boat or rivets/welded. I found a 1448 g3 all welded it weighs 400 to 450 pounds would that be to heavy for this motor or do i have to get a 1448 lowe rivetd/welded that weighs about half that.
Tue Oct 15, 2013 8:29 pm
Tue Oct 15, 2013 8:33 pm
what do you think about a fully welded 1448 g3 that weighs 450 pounds, seems like a tank to me.
Tue Oct 15, 2013 9:05 pm
Tue Oct 15, 2013 9:23 pm
http://www.g3boats.com/gator_tough_outf ... _jon_boats
1448
Tue Oct 15, 2013 9:40 pm
i wouldnt do it man..ppl have issues with those types of boats..theyre made for outboards not mudmotors..go with custom build is my .02
i ran a 23 gdsd on a 1645 all 1/8th for a while ran 24ish 25 and carried a load decent id go 16' its helps to plane the boat out and carries a load better than 14'
heres one of my old one
Tue Oct 15, 2013 9:56 pm
How much does that boat weigh? Money is a big factor for me im only 20 whats the most affordable boat that will hold up to this motor?
Tue Oct 15, 2013 10:20 pm
[quote="themilkman"]Getting a new rig for this duck season just picked up a 23hp go devil sd and was wondering what size boat you would recommend? Iv been looking at lowe, g3 and alumacraft some are all welded and some are welded with rivets. Thanks chad[/
Please make sure to get the right boat. I have a 23 GDSD. It is a solid little motor but making a mistake on a boat will ruin it. My boat kills the performance. Don't get a Lowe boat. It has a tall transom. You need a 16 inch transom. Don't get a G3. Make sure your boat is a 1648. Godevil boat or custom is best. If you want to save money get the 1648 alweld boat. I have a 1546 Southfork. It is too small. I am saving to get a custom built boat now. Don't make the mistake of getting a Lowe boat or a G3.
You will ruin your experience of mud motor riding. I learned from experience. That motor is fun with the right boat.
40HP Gatortail
Tue Oct 15, 2013 10:23 pm
The 1648 alweld will run about 24.5 mph and will perform well. If you want to save money go that route.
40HP Gatortail
Tue Oct 15, 2013 10:26 pm
Go devil website recommends a 20 inch transom for the 23 sd, still try to find a 16 inch transom?
Tue Oct 15, 2013 10:36 pm
it depends if your have a short transom or tall transom motor.
Short transom being 16 inch and tall transom being 20 inch
Tue Oct 15, 2013 10:50 pm
I also have been checking out the 1648 alumacrafts, there is a dealer nearby. Any thought on this boat?
Tue Oct 15, 2013 11:04 pm
Every day I'm paddlin'
Tue Oct 15, 2013 11:55 pm
Thanks for the help guys im looking at the alweld boats and the closest dealer is in oaklahoma and im in sacramento california and might order one idk yet.
Wed Oct 16, 2013 12:11 am
Even that alweld, as good of a boat as they are, for what they are, may leave you wishing you had gotten a true mud hull. Slick bottom makes a BIG difference!
Wed Oct 16, 2013 12:20 am
Hey man I'm new to mud boats I hunt a lot of flooded timber and marsh lands and iv been doing it with a out board but found a good deal on a mud motor. I'm just trying to find a decent boat for the 23 hp so the actual mud boats are just smoother on the bottom?
Wed Oct 16, 2013 12:39 am
Mud hulls are completely smooth bottom, no runners. Just saying you won't get full performance out of that motor if the hull isn't designed for it. And if you're running timber the .100" bottom won't hold up very long.
Wed Oct 16, 2013 1:05 am
I had a 1548 G3 with a 27 Prodrive on it and it was a dog. Empty boat it would only do 21. I had to learn the hard way also because at the time there wasn't a custom builder or dealer close to me. Please don't make the same mistakes that a lot of us have done in the past.
1846 GTB with GTR 35
Wed Oct 16, 2013 10:20 am
what exactly is your budget? you can get a custom boat built for less than the cost of a new brand name boat in most situations. if that is not an option and you have to buy used, try your best to find a 1648 go devil hull.
WC Custom 1854 huntdeck pushed by MB7000
Wed Oct 16, 2013 2:27 pm
I live in california and no one has bud boats for sell a new alumacraft and trailer is 4300 out the door but iv been looking at the g3s all welded duck boats but i guess there not that good.
Wed Oct 16, 2013 3:04 pm
before you jump into a g3 id check out craigslist or buy sell groups on facebook..might can find a used mud hull
Wed Oct 16, 2013 3:08 pm
A lot of people around here use rough neck lowes tracker grizzley g3 alumacraft some gator trax and other aluminum boats and they do just fine for what im doing but im gunna keep looking for a mud hull.
Wed Oct 16, 2013 3:23 pm
I suggest the custom route as well. Getting my boat built how I want it for a good amount cheaper than a similar size and layout "production" mudboat...My hull is going to be thicker than similar sized production models too.
Bobcat Mag 1 Pirogue with paddle
Brother Breaux 16x36 with a 23 GDLT
Wed Oct 16, 2013 6:04 pm
is a 20 inch transom to big?
Wed Oct 16, 2013 6:17 pm
What's your motor? Short or tall transom?
Wed Oct 16, 2013 6:23 pm
If you can find a used or new gatortrax there in Cali it will work fine.
Wed Oct 16, 2013 6:25 pm
If not buy a flat bottom Jon instead of a mod v hull.
Wed Oct 16, 2013 6:26 pm
i have the 23 hp delta edition surface drive not long tail but idk what size transom will work or if it matters and do pods help in the back of the boat?
Wed Oct 16, 2013 6:29 pm
their isnt any mud boats in the whole state of cali for sale im gunna be useing it for bass fishing and duck hunting here and their.
Wed Oct 16, 2013 6:31 pm
Wed Oct 16, 2013 6:34 pm
I run a 1744 alweld smooth bottom .100 with a 23 and it does great had a 1448 mod v before and wanted a new boat after 10 minutes a short boat can't ballance the weight of a SD. I thought I would be just hunting marshes then I found a stumpy lake to hunt and just going slow put dents in itwhen hanging it up on a stump. get at least .125 or your going to be throwing the hull away. Now I wish I would have spent an extra 1000$ and got a heavier duty rig. Love the boat and size it runs great stable night and day difference in speed handling load carrying over a 14' boat. Long and skinny with small SD is key 1740-48 1840-44
Wed Oct 16, 2013 8:44 pm
