It is currently Fri Jul 11, 2025 7:05 pm
Reply to topic  [ 75 posts ]  Go to page 1, 2  Next
 Anyone lost a prop like this?
Post Anyone lost a prop like this?
I was running in 3.5 foot of water and the prop just seperated. Anyone every seen a power tech prop do this?
Tue Oct 22, 2013 1:20 pm
Post Re: Anyone lost a prop like this?
OUCH!
Modded 36 PD draggin' around an 1848 PD boat backwards!
Tue Oct 22, 2013 1:30 pm
how did the motor react when the blade broke off? intense vibrations? I have heard this kind of event can bend a prop shaft.
Tue Oct 22, 2013 1:31 pm
Shook the motor so hard it broke the Mikuni carb mount, throttle linkage, lost the K&N filter and the prop shaft has some play now.
Tue Oct 22, 2013 1:35 pm
Rule #1 - Run your stock prop.
Rule #2 - See Rule #1
35 GTR - 1754 Extreme
Tue Oct 22, 2013 1:47 pm
Followed rule #1
and the prop was never damaged, repaired or changed in any way......plus it is only a year old and never even been in sand.
Tue Oct 22, 2013 1:55 pm
I had a prop tip get about a 1" crack that opened up a little when i hit something hard one time, but never lost an entire blade.
Thats has to be an imperfection in the metal.
Kool-Aid Brigade
www.southernfowler.com
Tue Oct 22, 2013 2:22 pm
Tue Oct 22, 2013 2:24 pm
Tue Oct 22, 2013 2:37 pm
Kool-Aid Brigade
Tue Oct 22, 2013 2:55 pm
I hit some sort of metal in the water and bent about 3/4 in on one side. I beat it back straight and ran the chit out of it. Finally wore the broke spot and it still has a crack in it. But didn't break off!
Sent from my beeper.
Tue Oct 22, 2013 3:07 pm
What kind of speeds are you getting with that? :lol: :lol: :lol: :lol:
Tue Oct 22, 2013 3:10 pm
It happens from time to time. Seen a few that broke before
17x48 extreme stage 2 GTR
Tue Oct 22, 2013 3:11 pm
1744 WC Custom
25 GTR
Tue Oct 22, 2013 4:05 pm
That prop was a ticking time bomb from the first minute of run time.
Tue Oct 22, 2013 4:13 pm
GatorHide - MB
Tue Oct 22, 2013 4:17 pm
Tue Oct 22, 2013 4:35 pm
Tue Oct 22, 2013 5:03 pm
I wouldn't expect Gatortail to warranty anything to do with the carb mounts, linkage or lost filter (I have already taken care of all of that)....Just the prop and shaft is what I hope they would warranty.
Wed Oct 23, 2013 6:41 am
Wed Oct 23, 2013 6:44 am
Wed Oct 23, 2013 6:49 am
Fixed the throttle linkage. I think this will work better than ordering another part from mikuni (they are not made to put the throttle balls on from the factory). I tig welded another piece on to the original linkage and taped it for the linkage ball.
Also i made a new carb mounting braket a little thicker than the other one I made :)
Thu Oct 24, 2013 1:48 pm
FTR that is not my carb brace
Thu Oct 24, 2013 7:50 pm
this prop was a bad casting. it happens alot on regular outboard props. when im rebuilding some props i find holes about 1/8'' dia. looks like someone drilled it and this is from the factory. when i tig weld to fill it they will kind of blow out to the size of a dime before you can weld them up. when someone loses a blade i cut one from a junk prop and replace it. they run good as new.
Sat Oct 26, 2013 8:06 am
Got the boat back from Gatortail Friday. I am very pleased....They replaced the prop, fixed the shaft and replced a bunch of things I didn't even see. So i have to say it was way more than I expaected!
Mon Oct 28, 2013 12:19 pm
Guess that's what ya'll SD owners refer to as half proping hu? 8-)
Mon Oct 28, 2013 12:27 pm
how many times you add pitch?
Mon Oct 28, 2013 12:32 pm
Had a buddy lose one off a prodive like that one time in Columbus lake but it all happen when you hit hard bottom.
Mon Oct 28, 2013 12:36 pm
I seen em do it,,but only on props that have been heated and pitched a lot. Shit happens i guess.
Mon Oct 28, 2013 12:38 pm
Mon Oct 28, 2013 12:43 pm
Mon Oct 28, 2013 12:44 pm
Mon Oct 28, 2013 12:46 pm
I need to figure out how to post a video.
Mon Oct 28, 2013 12:48 pm
4700 Coils
Mon Oct 28, 2013 12:49 pm
Mon Oct 28, 2013 12:51 pm
I know someone who had the same thing happen, also had the dual carb set up and it shook one off. He was running deep, open water but he had hit something the weekend before and figured that the prop got a hairline crack and it just kept cracking under the pressure until an entire blade fell off. Sorry that happened! Not a good situation to be in. I always take a good look at my prop after running it whether I think I hit anything or not. Doesn't take a minute and could be the difference in a great next hunting trip or an awful one. I've had enough bad memories with boats and don't need any more. Hahaha
35 Mud Buddy pushing a 756 Havoc MST
Mon Oct 28, 2013 2:17 pm
Mon Oct 28, 2013 3:43 pm
It just has to be a freak deal with faulty props.
I and lots of others have hit thousands of stumps without an issue.
Mon Oct 28, 2013 6:35 pm
Users browsing this forum: No registered users and 102 guests
