It is currently Tue Jul 08, 2025 6:57 am
[ 8 posts ] |
mudbuddy prop wear causes weird clanking.
goodbuddy13
my mudbuddy is making a bad racket in the bottom shaft area. the prop is seriously wore, and some friends and i think that may be causing an unbalance. wich is causing the noise. no play in the prop at all.
Thu Oct 24, 2013 11:37 pm |
eljefe
Joined: Thu Jan 13, 2011 7:32 am Posts: 5210 Location: Beaumont Texas
 Re: mudbuddy prop wear causes weird clanking.
What does the prop measure out at and you are probably right..... but look for a crack in the shaft housing about 10" from prop.
sent from the former Republic of Texas.
_________________ You can't see the sunrise if your eyes are closed. dying aint much of a livin....
Black ops IITX marshstalker
1840 WC www.wccustomboats.com fuel injected 25 GTR
Fri Oct 25, 2013 6:06 am |
goodbuddy13
its a 9/6 prop but i havnt measured it at wore out size. theres no cracks on the housing
Fri Oct 25, 2013 8:44 am |
Prodigy
If the prop is causing a vibration u need to get another one bro and get it off that motor.
_________________ Prodigy Boats https://www.facebook.com/Prodigyboats www.prodigyboats.com Contact for info - http://prodigyboats.com/contact-us/ 706-253-7766
Fri Oct 25, 2013 8:55 am |
wtyner86
check your bearings, a worn out bearing will let the shaft rattle around.
Fri Oct 25, 2013 9:02 am |
T10
Joined: Wed Apr 10, 2013 10:53 am Posts: 257 Location: ETX
_________________ WC Custom 1854 huntdeck pushed by MB7000
Thu Oct 31, 2013 12:51 pm |
SCSuperfly
If the prop is that bad then it probably trashed the bearings. You'll need to replace them fast before it does more damage.
_________________ Modded 36 PD draggin' around an 1848 PD boat backwards!
Tue Nov 05, 2013 5:58 am |
banded-mallard
I would have to think that excessive prop wear would do nothing other than increase rpm's, less resistance. If you run sandy hard bottoms, it sould wear even. So if it is indeed work, you should see nothing. If you hit something and 1 blade is worn more than the other, you should see excessive vibration due to the prop not being balanced anymore. The clanking sound has nothing to o with prop wear and is bearing related. Now, if you have excessive vibration in the handle, then check the prop.
Tue Nov 05, 2013 6:19 am |
[ 8 posts ] |
Users browsing this forum: No registered users and 34 guests |
