Re: Mudbuddy upper bearing collar removal??
If your talking about where the bearing and seal set is in it's called the housing. In that case you heat the housing up near the drive shaft tube and using a pipe wrench work it back and forth while tapping it off the tube. They use some sort of adhesive on it.
