It is currently Tue Jul 15, 2025 11:26 am
Reply to topic  [ 12 posts ]
 Fuel pump problems will this work
Post Fuel pump problems will this work
Ok here is ma situation think it will work but not sure went hunt yesterday and got out there ran through some shtick stuff. Ok I have cdi motor with the fuel pump on the side the motor and a mikuni carb we'll the barb coming from the fuel line broke going in to the fuel pump and my hose was not long enoughy to reach the carb direct so I used a butt connector to connect the two fuel lines to get back to the landing so here is my question a while back my manifold broke and my buddy gave me one off a old motor. We'll that fuel pump on the motor has that extra hose going to the manifold but it's not connected cause the old manifold does not have that but I have a electrical fuel pump. Can I just run the fuel line direct to the carb or do i need that fuel pump On top the motor also
2010 gtr cdi with a stage 2 pushing a 18x46 home made HEAVY DUTY boat
Wed Dec 25, 2013 9:54 am
Post Re: Fuel pump problems will this work
:lol: you talk funny!
It will run fine with the electric pump, but imo I would just replace the stock vacuum pump. I have no faith in the electric ones especially for a primary. Use the electric for a primer and back up.
Wed Dec 25, 2013 11:39 am
Even though it does not have the line going to the manifold the stock vacuum will still work
Wed Dec 25, 2013 1:33 pm
Wed Dec 25, 2013 1:38 pm
Wed Dec 25, 2013 2:08 pm
Yea I guess I could drill and tap it out bieng that I work at a machine shop
Wed Dec 25, 2013 4:00 pm
Y'all wouldn't happen to know what thread it is I'm. Sure it's a npt thread that way it tighten up as you screw it in but will the size of the ID of the fitting matter
Wed Dec 25, 2013 8:43 pm
Wed Dec 25, 2013 9:01 pm
As long as its not 3/8, 1/2, 3/4, 1", etc... lol
Go 1/8npt my boy.
Wed Dec 25, 2013 11:23 pm
Yea I was thinking 1/8 cause we do a lot of 1/4 npt and that would be way to big cause a 1/4 npt is a 7/16 drill bit
Thu Dec 26, 2013 4:54 am
^ Exactly
Thu Dec 26, 2013 4:17 pm
For the time bieng it's getting hooked direct because I called gator tail that lil piece is like $120 and I don't have time to take the manifold off and drill and tap it but thanks for the help it'll get done eventually
Fri Dec 27, 2013 5:08 am
Users browsing this forum: Hunterk, Majestic-12 [Bot] and 131 guests
