It is currently Tue Jul 15, 2025 10:01 pm
Reply to topic  [ 19 posts ]
 Pod Performance
Post Pod Performance
I recently bought a 1748 southfork w/GT 35. The boat has rear pods attached. I'm not getting the performance I'd like. Just wondering if cutting them off will help significantly?? I know this has always been a beat down topic but I'm asking for some input people have experienced. I hate to cut them off then the boat not perform any better. I run mostly deep water and I just cant get the boat to the speeds I was hoping for.
Thanks
Sun Mar 30, 2014 8:39 pm
Post Re: Pod Performance
Cut em.
Sun Mar 30, 2014 8:45 pm
I've cut them off 2 of my boats. What speeds are you getting,Whats in the boat, Motor mods? Need more Info.
Mon Mar 31, 2014 6:01 am
In the boat is 1 battery, 6 gallons of gas and life jackets ect. Speeds by myself in deep water is 22-23. No mods on motor. New prop.
Mon Mar 31, 2014 6:21 am
Cut em
Sent from my SM-N900V using Tapatalk
Stage 2 Mini 23 chasing a 1642 Prodigy
Mon Mar 31, 2014 5:13 pm
Eat - Sleep - Hunt ! ! !
Mon Mar 31, 2014 7:00 pm
I'll try to get some pics.
Mon Mar 31, 2014 9:37 pm
Mod v front but completely flat with no hooks or dents.
Mon Mar 31, 2014 9:41 pm
A 1748 should not need pods to run flat with a 35.
you drink the kool aid, id rather drink the whiskey and raise hell!!!!
Black ops IITX marshstalker
1840 WC www.wccustomboats.com
fuel injected 25 GTR
Mon Mar 31, 2014 9:43 pm
Where is your gas tank and battery?
Mon Mar 31, 2014 9:44 pm
Have you check - out of water max rpms - to see if it will turn 4100 rpm ???
Pods don't look too bad all in all they are well made.
Mon Mar 31, 2014 9:54 pm
The out of water rpms are 4100+ but in water I struggle to get 3600. I did notice my transom is 17" and saw where short GT needs 16. This should throw me off that much would it??
My tank and battery are in the back.
Tue Apr 01, 2014 6:30 am
Move gas to front.
Tue Apr 01, 2014 6:33 am
Move gas to front. Surface drives run best flat. If all the weights in the back it won't get flat. Probably why the pods are their. And yes 1" on transom height can make a difference. It's changes the angle of the drive......
Tue Apr 01, 2014 6:41 am
I agree with Eljefe - did I just type that - LOL
Also try changing the motor pin to the other holes...
Also put a second person way up front to see if there
is an improvement - or take a big ice chest and put water
in it for ballast....
Tue Apr 01, 2014 6:58 am
How much of the prop is out of the water at 3600rpm?
Tue Apr 01, 2014 10:12 am
I'd say roughly half. Since my transom is 17 I did move to bottom hole. Perhaps I should try top hole. I notice after moving from middle to bottom I seem to run out of upward trim. The trim is maxed out. I put a large 300 lb guy in the front but never gained anything as expected due to weight. The mph was close to same but max rpms were 3300.
Tue Apr 01, 2014 11:02 am
Go to top pin .. Should help
1744 WC Custom
25 GTR
Tue Apr 01, 2014 11:58 am
You may be over proped. What prop are you running, you may try a smaller top pulley if i the boat does't have any hooks, and prop is new and a gt recommend prop. Check engine health before removing the pods. A compression test should have both sides about the same. A leak down test is a better test if you know how.. I have a buddy that weights about 350 and had a light 17x48 that ran like shit until he put pods on, I am not going to post his speed , most here would not believe them if I did. If the pods are creating lift and not drag they are not the problem. Checking with a straight edge the pods should flow just like the bottom of the boat ,or just be a little higher, is the bow plowing.
JD
Fri Apr 04, 2014 4:16 pm
Users browsing this forum: Google [Bot] and 90 guests
